Looking to build my own trike and turn it into E-Trike
dan-the-man
๐Ÿงฒ New user
KdksWn8UCnnWal43@#
Hi guys,
Let me first say that I am very good with tools and so building something is simple for me.
I am a disabled person and always wanted to cycle on trikes for recreational purpose, but after looking at the price tags on all these trikes (FreedomRyder, G Force, etc) I decided to build my own. However, I am not an expert by NO MEANS. I don't know all the fancy words or jargon to describe bicycle parts. So, here is my plan. Have a look at the picture. At least for now, that is my design and plan and I know it will change as I am building. I've circled the parts that I would like to know the name of to make a purchase. Can someone help me? If not, point me to a website where I can buy any and all the parts I will need to build this bike. Also, can someone give a list of parts I will definitely need to build a trike like this. Eventually, I will convert it to E-Trike. I've seen E-Bike conversion kit all over the internet. Thank you for all your help.
My first thought is this search, and to soak up the solutions. Some of them are proven.
https://www.google.com/search?client=ubuntu-sn&channel=fs&q=handcycle
My next thought is that steering and handling are not a trivial problem over walking speed, and that I'd probably want to buy a manufactured steering front-end to mount at the front so I can have the benefit of al the esoteric engineering knowledge that has been so hard-won by other's work.
I would have that in mind while looking through the pages found above. You don't say how you want or need to handle your legs. You'll need to take that into account, and we would need to have some of that information to be able to advise as for most humans, they will also be in the vicinity of the steering gear.
That's the start I think of.
Can't you find and buy a (second hand) handbike in your area? If you are using a wheelchair you can get a hand bike that attaches to the frame of your wheelchair.
The main issue I see is that you'll need a secure, well-reinforced joint between your wooden keel's forward end and the upright (metal?) that holds your headtube (which will also need to be securely mounted to the upright). The forces on that area especialy under even minor bumps will be huge, and can cause catastrophic failure while riding. Depending on the materials used, it can be sudden and without warning.
I used welded steel to build the SB Cruiser from, and I still have a weak point in the design involving this issue, where the loading at the front edge of the cargo/seatbox has twice broken the keel. That specific failure mode probably won't happen on yours, depending on the size of your keel (like a 4"x4" post) and how you mount the seat to it, but the laoding on the headtube/downtube/keel mounting point will be very high in lateral and forward/reverse directions which will occur all the time while riding. Vertical loading will also happen, but that's easier to build for. The ability of the wood to twist in torsion will help with the lateral loading, but the forward/reverse loading could cause the whole front end to snap off at that point once enough damage to the joint occurs.
Adding triangulation from the headtube down to under your seat, as far back as is possible to do, will help, but the specific method chosen to connect the different materials will matter quite a bit.
Optionally, you can use a handbike attachment for a wheelchair (either already equipped with a motor, or not) as the front end of the trike. That would also solve you having to build the handbike cranks out of regular pedal bike cranks, as well as adapting that bike's bottom bracket (BB) frame / etc onto a fork's steerer.
Parts are easy to salvage from other old bikes from bulk trash piles, local bike shops or coops that keep scrapped bikes aorund for parts, thrift stores, freecycle / trashnothing / craigslist / etc. That's been my sources for almost every bike part I need for my builds. Most of them were free parts, others extremely cheap.
BTW, for the seat itself, given your drawing, I would recommend the StadiumChair (as I use on my rides) as it will save you construction work (even if you have to modify it for a more reclined position) and it is quite a comfy seat even for long rides. The company itself is responsive to customer inquiries as well. (there are clones of them, but they are not nearly as well made, and their steel is much heavier and cheaper and weaker; I have both types). They also make wide versions if you don't like regular seat widths.
If the "wings" on either side of your front wheel are footrests, you may need to build those onto the fork itself rather than the trike frame, so that they pivot with the wheel, or you may have to place them quite far apart to give the front wheel space to turn. If you only need to make very wide turns, it won't take much space, but if you ever have to make tight turns it could be a serious problem if they're too close to the wheel and mounted on the trike frame. But mounting them to the fork means they will move out from under your legs while turning, and the sharper the turn the worse the problem. Depending on the level of control, feeling, strength, and movement you have, it could be possible that unless they're strapped or clipped in, your feet could end up "sucked" under the trike after falling off the rests. :(
For the rear end, there are several ways to mount the wheels, depending on which wheels you want to use, and which motor drive system you prefer. There are trike kits designed to turn a regular bike into a trike which would make it pretty easy to build the whole rear around. That's how I built both Delta Tripper and the present SB Cruiser, and the Schwinn trike conversion Amberwolf's Schwinn Trike Rebuild / Conversion to Heavy Cargo Hauler also has one though I'm not using it that way.
Or if you are building from scratch, you can use a differential (like peerless, or cheaper versions of the same type of thing such as were used on the ancient Schwinn trike I'm converting in that thread above). Then the chain can drive the diff, which then drives both wheels even when turning.
With a diff, you can either drive the diff from a mid-mounted motor (even a hubmotor mounted without a wheel) along with the pedal chain, or you can use hubmotors in the front and/or rear wheels. If you use them in the rear with a diff, you would either need to customize the hubmotors to mount to and work with a diff's live axle, or you would need to do something like I am doing on that Schwinn conversion, where a chain or belt from the outboard end of the diff axle drives a sprocket mounted to the motor casing (with or without a freewheel depending on what you want the system to do for you).
You may also want to look at my SB Cruiser thread for an example of a working delta trike design. You can easily leave off the cargo box on the back and leave it an open deck or even just open frame, but it's been working for me for about a decade so far. The SB Cruiser : Amberwolf's 2WD Heavy Cargo Trike & Dog Carrier
There are many other possible trike designs as well; and many threads about them here on ES with discussions of CoG, wheelbase, width, height, steering considerations, wheel drive methods, etc., if you haven't already found them.
If wood is your construction material, check out the 'wooden 3 wheel car' built by youtuber 'way out west' featured in these lists already though im far to lazy to google links atm.. iirc plans are available for reference.
the Big problem with trikes is cornering speed/stability.
Thank you all for the replies. My issue isn't that I can't come up with a sound design that is easy, safe to build and ride on, but it is where you can find the parts you need to get your idea off the ground. Believe me that drawing in my original post is just a basic idea and I am certain it will change a lot as I find parts and other things to build it with.
So, I've looked and looked all over the internet, but can't seem to find bicycle or handcycle parts. I found some sites but very limited. However, there are a lots and lots of websites selling bicycles, tricycles, handcycles, etc, etc, etc... I am guessing cycle part suppliers are closely held secret amongst cycle building communities. lol...๐Ÿ™‚๐Ÿ˜ If only someone could show me where I can find bicycle or handcycle parts, that would help me a LOT...
I've also looked for second hand or used handcycle online and found bunch of them, but they are still expensive for how old they are. Some guy wants $2,000 for his handcycle that looks like it has seen a better day and about to fall apart. lol...๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
I just don't want to spend all that money only to spend next 5 years fixing it spending another $2,000 buying parts...
Thank you guys for all the info and suggestions.
Which specific parts are you looking for?
There are bicycle parts sold at dozens, if not hundreds or thousands of bike shops' websites, regular websites for other things, etc.
And as I noted in my first post in this thread, the "best" place I found to get them is used bicycles from thrift stores, yard sales, freecycle, craigslist, trashnothing, etc. Most of the time crappy bikes are available for free or nearly so, better bikes for cheap ($25-$50) and sometimes free, etc. You can even post your own want-ads on various sites asking for bikes for parts for a project. (I picked up a trailerfull last year for the cost of the time to ride a few miles and get them).
If you require brand new parts it'll likely cost a lot more--each part may cost you $50 or more, dependign on shipping, etc. Some parts might have to be bought new depending on what you are after, but most can be used off old bikes for most projects.
