Here are the relevant(I hope) details:
24-48V 20-amp analog pedal-first controller
Crystalyte 407 rear wheel
48V 10AH ping 1.0 LiFePO4
Battery's BMS temperature <110 degrees Fahrenheit
Battery's temperature <100 Fahrenheit
Ambient temperature ~= 89 degrees Fahrenheit
"Cycle Analyst" shows that 7-7.1 AH have been used.
I'm double-checking the last figure by clocking the 2-amp charger's charging time. It seems to be pretty predictable when it's going to be done when I know the amount used according to the Cycle analyst. The 7.1 AH was used over three separate rides over a period of a week, so I'm wondering if I reset the Analyst accidentally, thus my double-checking but I doubt I reset it.
The history of the Battery pack is that it was actually recently purchased used from an Endless Sphere member who purportedly used it as part of a parallel 2 48V 10AH ping lifepo4 set-up(20 AH, effectively) for 1500 thousand miles on a 40amp controller in a slightly hilly area so it's guessed to have been charged approximately 50 cycles, according to him. His posts here seem to corroborate the mileage, so I don't doubt it.
Looking at Cycle analyst to check what voltage/amp conditions it was cutting out at, I found that A-Max varied between 21-38 amps with V-min varying between 43.1-43.7v as I tested it 4 separate times to cutout(I had to manually plug/unplug the battery to reset it.).
Does the voltage/amps shown correspond to whatever ping's voltage cutout and/or current cutout is? If not, what might be the problem?
