PhilExplore
100 µW
Hi
I built a 60V battery out of Samsung 50S cells, double checked spot welder - tested. 6 cells in parallel, amp draw could not be more that 60 amp as that was the controller limit, with 6 cells in parallel, Samsung 50S could handle 125amp easily.
Battery has JK bms with balancing and a lcd screen, these are new cells and my problem started on my 3rd ride.
I made sure to leave the battery to self balance before charging, and again after charging, to ensure all groups were equally charged. ( to 96%)
Basically on the ride I was checking the screen every 30 mins to change the battery with a smaller spare one to get home when it reached 3.15 V overall.
I should have stopped as one bank was showing 3.06V while the rest was at 3.12V, then the battery died, I have good gearing on my bike so I could pedal home - slowly.
After dissection, 5 cells out of 6 showed mV or reverse voltage. I am guessing these cannot be fixed?
This is the 2nd time this happened, I got new cells to replace those that went mad, again in a different group. I did notice on my 2nd ride that the voltage in another group , not the one that had the issue , got lower so I let it self balance before charging.
Has anyone have a clue why this is happening, I think I am just going to buy ready made batteries from now on.
I redid the spot welder on a few cells including the one in the picture to the right. Meter shows the lowest bank next to the cells that have failed in blue, marked a good cell by mistake.
Thanks
Thanks
