ebike4healthandfitness
- Joined
- May 19, 2012
- Messages
- 1,283
litespeed said:For me, moto rims and tires win hands down simply because they work. Shinko 241’s are just amazing on my 125 lbs “17 KW 65+ mph bicycle!” I’m a pretty smart person and know that the rotational inertia is higher which does slow my acceleration/braking but, and I mean a huge “I like big butts” but, ( I actually do not like actual big butts by the way!!!!) the traction, sure footed feeling, longevity, flat resistance and over all feeling out weighs (pun intended!) the parasitic losses in my opinion. Even when I was running 14kw on a maxed out MaxE running a 3.0 26” Minion down hill (was supposed to be the best at the time but tried a few others with same results!) bicycle tire I could never keep the front end planted in a hard turn with power. On street the knobs were too little, too soft and on trail not enough grip. I had too much power and made the front end too light. Grab too much front brake and the front end would wash………But, even with my 19 x 1.6 rim with a Shinko 241 2.75 the front end comes up with a flick of the right hand but has grip for days on street or trail. Believe it or not but I’m faster through the corners and trails with the heavier tire. Your results may be different but mine are as stated! How many times have I had a flat tire on bicycle tires…..more than I care to admit. Had more than my fair share of walk of shames! Granted now there are thicker tubes, slimey shit to fill them up with, extra tube protectors, blah, blah blah that I have not tried but I feel no need to. I don’t need them with my Shinko tires….nor do I need or carry a patch kit…..never did on my motorcycle either.
While many may be faster my bike will do 0 to 60 mph in 10 seconds. With a 220 mm front disk/MT5e I can do a stoppie (I’m not good at it and it scares the shit out of me when the rear end comes up…..just compressing the 7+ inch front fork will get you clinched up tight enough to turn a piece of coal into a diamond of really good quality!) and can lock up the rear brake at any speed with a 203 mm/Hayes Stroker Ace with 2 fingers. While I’m sure a lighter set up could do it faster or better, I don’t feel I’m giving up much.
So I’m 6’-4” and 220 fit lbs. I have a dirt bike background my whole life. Even having the best motor bikes available there were always compromises that had to be made and on my ebike this is the one I have made. Since I have a QS 205 V3 hub motor ebike with the motorcycle tires I am able to run at lower PSI which helps mask the weight of it. Compared to bicycle tires I have had to run at higher pressures to keep from pinch flatting is night and day. The chatter from small trail imperfections even with 10” of wheel travel is enough to sterilize the most vibrant man out there. The motorcycle tire is like gliding on a cloud. So is this for everyone? Maybe not but for me there is no other way. If I was just doing this or that, looking for the utmost performance or racing the bike my compromises may be different. For my all purpose, jack of all trades, do it all crazy powerful always ready to go, non tire repair kit carrying black beauty motorcycle rims and tires are the way to a better ride. <mic drop>
Tom
Great post.
I've seen those comments from other people elsewhere. Interestingly, some people found out about the increased grip on accident because their original reason for switching away from bicycle tires was to save money (re: moped tires last a lot longer than bicycle tires).
