Nanrobot d4 wiring diagram
I don't know of a wiring diagram available for them, and a quick google doesn't find anything useful.
Most likely you'll need to trace out the wires and draw the diagram up, marking it for which wire goes from what device to what other device, and what color it is.
Once you have that, then someone here can try to help you figure out what each function is, and whether it is possible to use it without the "keylock".
It's likely you're going to have to use a multimeter to test for continuity and voltages during the process.
