ScooterMan101 said:See how the rear shock in the above post is almost vertical . many bicycles have shocks that are near horizontal .
Do you think you can design a swingarm ( that would bolt up to the em3ev.com EEB frame ? ...
With the / a big block motor ( lightingrods/GNG 3000w / Cyclone 3000w ) in front of and below the shock .
Move the lower part of the rear shock backwards and up with brackets coming up from the swingarm , with the shaft/cog on the motor located just outside the left side bracket . And make a small heat shield for the shock to route the heat from the motor around the shock, a coil over shock will be necessary a coil shock a good thing anyway air shocks are for lowering weight , a half pound is not so important on a high power e-bike.
Increase the wheelbase a little, and since those e-bike frames do not have a slack enough head angle , make the shock bracket so it slackens the head angle about 1.5-2.5 degrees .
Well, it is already available for the Cyclone coaxial motor as below:
You can actually buy just the Chain drive Coaxial Motor Kit with Swingarm for Enduro e bike frame include: Coaxial motor, 32T, bluetooth programmable controller, throttle, crank set and Swingarm for $649 here: http://www.cyclone-tw.com/Coaxial.html
