Hello everybody, my name is Roberto and after some useful lecture here I'm trying to build my first battery pack.
I need to power a trolling motor for a catamaran, and at this moment I'm using a Lipotech 45 Ah battery LiFePO4. The battery is perfect for my engine, but the weight and the "shape" is not so easy to manage on my small boat. In the sealed marine box the battery is huge.
So I thing to build a light battery pack in a small and long shape to "hide" under the structure, but I have some questions.
I think to use Panasonic batteries, 2900 mAh and 3.6V. Using 40 batteries, 4 in series and 10 in parallel I will obtain, If I understand some FAQ here, 14,4V and 29 Ah.
First question: is there a way to obtain a lower voltage, maybe with a different cell type?
Second question: I'm trying to find a PCB to manage my battery pack but I don't understand which type of PCB could be ok for me.
Thank you su much, I'm trying to learn here but there are a lot of topic about 24V or 36V battery pack...
Here some data of the engine:
power 32lb, 312 watt(max speed), 0,42cv, 12volt, 26A,
