rob-boss
🧲 New user
Im trying to turn an alternator into a motor. the alternator with its other electronics removed needs the rotor to be electrified and the stator needs the 3 phase cables installed in the right order. no phase combination worked. nothing ever specified where to wire the motors power supply vs its phase lines so i just connected the motor off of the battery cables right before they enter the controller.
I wired the throttle how the diagram said to except for the yellow wire which i don't know what to do with. the throttle display comes on but it displays a dead battery even though the battery is fully charged. the throttle does not make the motor spin in any phase line combination.
The motor positive and negative comes from the battery cables right before they connect to the controller and the phase lines come from the controller.
there are 2 brake sensor lines. i combined both positives and negatives and tested each phase line combo with the lines connected and disconnected to no avail.
the controller page said its supposed to work with the hall lines unplugged. the battery im using is 24v 20Ah with 20A discharge rate. can anyone help me figure out how to wire the power correctly to the motor and controller?
