lesdit
OK, I've got a rather odd e bike setup that I'm working on, and I need a bit of bike tech help with the bottom bracket.
The bike has a 83 mm bottom bracket shell width, which had a Shimano hollowtech 2 bottom bracket and crank set in it. I have a cyclone 1200 kit that came with a 135mm length taper spindle and some aluminum cranks.
Now here is where I am confused because I am not very familiar with bike parts in general : Can I just get a bearing kit for the cyclone supplied spindle and fit it to the BB shell on the bike ? Since this DH bike has a rather wide shell, will the bearings 'reach' the races on the cyclone spindle , which are about 56mm apart ?
The funny thing is that the extra length spindle that came with the cyclone kit puts the cranks and pedals at the same spacing as the original shimano hollowtech 2 setup the bike had originally!
I don't mind using the old school taper spindle if it can be made to work, but I'm just not sure if it can be used, since it was a generic type of kit that wasn't designed for down hill bikes with their oddball sizes. Any advice from bike savvy mechanics would be greatly appreciated. I have access to a machine shop, if that is needed.
