recumpence
1 GW
Hey Guys,
I am currently collecting parts for my second build. This is not my mountain bike. That will be done as well. However, first, I want to build a bike that is more "From Scratch" as a real performance machine. To that end, I have decided on a few criteria;
#1 It will be a 20 inch wheel BMX style bike. I want a long frame (long by BMX standards) with a euro bottom bracket for FW cranks. I have always loved this size bike and have always wanted the ultimate "Urban Assault" BMX bike and this would be it!
#2 Disc brakes front and rear.
#3 Chromoly frame for ease of welding and durability.
#4 Multi speed hub.
#5 Four to five KW of power.
Now, I will probably start with either a trials frame (long with euro BB) or a similar cromoly BMX frame and mod it to my liking. I already have the cranks and will be ordering the BB soon. I really need to know the most durable internal geared rear hub. I have heard there are very durable hubs and weak hubs. I want a strong multi speed hub that is disc brake compatible and 36 hole. Remember, the wheel will be 20 inches. That will reduce the load on the hub to far lower than a 26 inch wheel would give. So, that helps. Suggestions on a hub? Best place to buy it?
I also want advice on 20 inch rims. I want strength! Also, I will be running 2.25 inch road tires. So, wider rims would be best.
This bike will be built around my drive (in two stage guise). I will either run my Plettenberg on it (with CNC's 40 series motor on my recumbent). Or possibly two of CNC's 40 series motors (that way I can run two ESCs to handle more power). The motor and drive unit will be inside the frame triangle. I am willing to cut and weld the frame as needed. But I really want the drive inside the frame.
The battery will be high C rate lipos (I am very familiar with them). I will probably make up my own pack in the 7 or 8 AH range (48 volt pack).
This bike is meant for hard riding (borderline abusive riding). I want absolute durability! I want strong everything! I will be riding wheelies, taking it down steps, just plain riding HARD. It will be sort of a very light weight stunt motorcycle. It should accellerate HARD, stop hard, and take a beating.
Anyway, let the suggestions begin!
Matt
#4 Multi speed hub.
Matt
