You may need to make adjustments for changes in voltage: i.e There is a low-voltage cutoff in the controller, to protect your batteries. A 72V controller will need to have the LVC adjusted or defeated to run @ 48V.
TD, the 72v clyte units have a 29v cutoff. Justin is also modifying as many of them as he can for a 20v LVC. They'll be fine.
Whatever voltage you run, you won't have the convenience of an automatic LVC programmed into the controller. You will need to manually watch your battery voltage or program a LVC into the CycleAnalyst.
Ok, screw the nimh. Nimh and nicad is "old school." Sla's are "ancient school." Li-po's are for "bomb school." And Lifepo4's are "college graduate school." :lol:
