xyster
Found these "smart cable" lithium charger adapters:
https://2339072343.monstercommercesites.com/index.asp?PageAction=VIEWPROD&ProdID=3285
They sell them for one to four cell chargers for their 3.2V 1.3AH A123-like high-rate LiFePO4 batteries (which they've just dropped the price of too):
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3071
(note the different domain names of the two BS links-- wonder what's up with that?)
Too bad max charging current is 1 amp. Would a couple work in parallel with my single-cell 1.5A lithium chargers in order to charge subpacks of A123 cells (that I may, over time, replace my lithium cobalt cells with subpack-by-subpack)?
Could these little voltage regulators be over-amped without damage or a change in the output voltage?
* The smart cable is designed for converting a 3.7V smart charger' into a smart charger for 3.2V Li-Fe-PO4 cell at lower cost.
* Just plug the cable's two hole connector into 3.7V smart charger' s two pins plug ( big hole or / pin is positive )
* Specifications
o One DC regulator is installed inside cable and provide 3.8V cut-off voltage.
o Max. charging current : 1 Amp
o Cut-off power when battery pack ( 1 cells) is full
o Red wire / clip is positive polarity.
o Please sure charger's polarity match with battery pack's before charging.
