CGameProgrammer
I'm wrestling with the question of what BMS/charger system to use for an A123 pack I'll be building. I'd like information on the pros and cons of various options. The ones I'm aware of:
DeWalt BMS and charger
Pros: The BMS is essentially free and the charger is roughly $50 on ebay, sometimes less. No assembly required, simple to use, BMS is fairly compact (the wires going to it need some space though).
Cons:
The BMS is impractical for discharging but can refuse to charge the batteries if they get too out of sync. Requires series depth to be a multiple of 10. The BMS is destroyed if you plug it into a live (plugged-in) charger before plugging it into a battery pack, or the reverse - unplugging it from the battery pack before unplugging it from the charger. So you basically keep the BMS connected to the battery pack at all times just to be safe, even though you're only using it for charging.
Notes:
I would assume this method is safe if a multimeter and single-cell charger are also used in the event the pack is too out-of-balance to charge. Use the multimeter to find the problem cells and use the single-cell charger very briefly to bring them up to the same level as the rest. Then continue charging as normal. Still kind of a pain though, but I assume this situation only occurs if the cells are depleted beyond 80% or so. Thoughts?
DIY BMS (GGoodrum/Fechter)
Pros: Compact (...?), full-featured. Works with any series depth. Best tech support available.
Cons: DIY, several hundred components to solder in, actually not that cheap ($130 for 24s not counting shipping, and over $200 for 30s since you need to buy two PCBs), charger sold separately, you will probably need gary/fechter's help. At least I sure would.
Swarms of single-cell chargers
Pros: No BMS needed whatsoever (for charging) resulting in the smallest battery pack possible. Nothing can go wrong really. Works with any series depth, obviously.
Cons: Somewhat high initial expense. ($13 per charger so $312 for 24s.) Will need daisy-chained power strips and will be very bulky. Reportedly the VoltPhreaks charger in the above link cannot be placed adjacent to each other when charging cells in parallel because they'll overheat, making dozens of them even more bulky. Totally nonportable except individually (hope you're patient). Obviously no discharge balancing. The VoltPhreaks charger only charges at 2 amps so worst-case it takes one hour to charge for every cell you have in parallel (six hours for 6p) assuming you have one single-cell charger for every cell in series and charge them all at once.
Notes:
No idea what the power requirements are here. Is a single typical 110/120V outlet good enough or are multiple outlets probably needed for 24 7-amp single-cell chargers running at once? Are there any other disadvantages I didn't think of?
BatterySpace "PCM"
Pros: Seems to do everything needed for both charge and discharge balancing; ready-to-run.
Cons: Expensive and bulky, especially if combining two of them for a non-standard cell count (such as 28s; the 60-amp 12s and 16s combined are $350 and twice as big as just one). Charger sold separately. Possibility of breaking?
iCharger 1010B charger/balancer
Pros: Ready-to-run, fully balances up to 10s, capable of quick-charging, extremely configurable, fairly compact, charger and balancer are a single unit.
Cons: Really expensive ($190 at the above vendor for each 10s subpack), no discharge protection, seemingly limited information on it on this site (though tons on RC forums).
Cons:
Notes:
Notes:
BatterySpace "PCM"
