Finally finished my board but it's really slow. I'm guessing 10mph. Here's my setup:
Hobbywing Ezrun 150a (programmed to soft start, timing 26.25, and 6s)
Tacon Bigfoot 160 245kv motor
3-2s Zippy 5000 lipos in series
Caliber trucks
Abec 83mm clones
24tooth motor gear
44tooth wheel hub
Spectrum Dx2e Radio System
I give the board a few good kicks before hitting the throttle and she goes. If I give it full throttle it seems to cut in and out. If I keep the throttle around 75% the board rides fine but quite slow.
I'm waiting for a 12s esc to come in. Should I bump up the battery packs to 8 or 10s or should I change the gearing?
Any recommendations would be greatly appreciated. Thanks ES, I couldn't have gotten this far without you guys.
Caliber trucks
Abec 83mm clones
24tooth motor gear
44tooth wheel hub
