maxchilton said:
astilwell611 said:
Even though it's still a 50mm It seems to get a lot of good reviews here on the forum.
http://www.hobbypartz.com/96m608-bigfoot160-5335-245kv.html
this motor is 63mm in diameter, 54mm in length.
From what I have read online from owners of the The Tacon it is a great motor! Especially at that price!
However The Tacon Big Foot 160 245kv motors are now out of stock.
Also I can confirm at this stage they won't be coming back. The reason for the price reduction is to clear out their old stock. If for some slight chance they do come back they won't be $55 as its under the cost price to manufacture the new improved premium version which is what I offer in the 6355 190kv R-SPEC Motors.
So how do I know all this?...well as has been suggested by some people already....I have finally been able to confirm that these Tacon Bigfoot motors are from the same Factory as the R-SPEC Eboard Motors.... originally they denied it but I kept pushing them for info, so they went back into the archive of sales. They found that the TACON motors were actually ordered from my factory over 2 years ago & this is the last of that order. They have not ordered anymore... probably because the price is much higher now.
The Tacon Motor has a great reputation but the interesting fact is that those Tacon Bigfoot motors are actually the "budget/entry level" version from this particular motor factory. That version is now discontinued.... as the factory only wants to produce premium motors now.
The main difference between TACON & ENERTION R-SPEC is the bearings & stators found in the TACON BIGFOOT are Chinese grade components. Also the R-SPEC Stator & windings are treated in a chemical bath to make them water resistant!
The Chinese grade silicone steels used in the stators of the TACON motors are a lower grade material with thicker laminations and therefore have much greater losses. Chinese bearings are also generally low grade and lack precision, the cheapest ones on the market are commonly made with recycled metal which is much softer.... basically they wear out quicker which results in friction losses! Bearings can be replaced though! Stators cannot easily be replaced.
The low grade silicone steel used in the stators is the main difference between Tacon & Enertion R-SPEC. With the lower grade steels & Standards used in Chinese Stator manufacturing you get greater Hysteresis & Eddy Current Losses. So you do end up with a cheaper motor but one which is less efficient & runs hotter.
The Bearings and Stator used in the Enertion R-SPEC are now sourced from a specialist Japanese stator supplier that uses specially developed "electrical steel" with high silicone content to minimize hysteresis..
My motors are not the cheapest ones available but they are the best I have been able to find... Also they are designed for electric skateboard as they have a machined shaft with a keyway that is compatible with the Pulley you have (assuming it has a key?), the motor wires are long, flexible & made using quality high stand count copper silicone insulted wire.. which is about $2 a meter... it all adds up.
Sorry to hijack your thread, but I only just got this info & thought I better clear up some things.
