Well it's been a month now since I've had my Build together, a Giant Trance X3 Full suspension with a BBS02. The system was SUPPOSED to be powered by a LUNA Cycle, 52V Might Mini Cube. While this looks like an awesome battery with 6ah of capacity in such a small package, due to an issues with Luna not shipping me the proper charging connector, I still cannot use the battery! Argghhhh (it's in the mail now)
Here's the bike with it:
As not being able to ride it was killing me, this required some improvisation to test out the BBS02. While at Home Depot I came across some of the EGO 56v power tools. As the battery is only 4v more than the Luna one, I thought I'd pick one up and give it a shot to see if I could finally get my bike working.
Well I had to destroy the string trimmer that came with it to take the battery connector out, but sacrifices need to be made..
Now it's not pretty (and not safe!) But it works, and it works well! This battery gives me even a little more power, and my bike managed to hit 50kmph full out.
Now the issue becomes proper mounting. As you can see this isn't a safe setup (although no problems the past month), and although the pack (I think) is mostly water resistant, it's not something to use in the rain)
Now I just wish I had a better/proper way of mounting this battery pack. My three options are:
1. Cut the whole mounting piece from the power tool and mount it to the bike somehow. (Ugly)
2. Find a seat bag big enough to fit this thing
3. Custom make a mount
I like the idea of the battery on the seat post as it gives me room to mount my lock (currently you can see it below the battery). I had this water bottle mount which you can see on the seat, which I broke apart a bit to see if I could make something work.
Now that doesn't hold at all, but gives me an idea of what could work. It would be amazing if I could use a similar mount that I could screw in some sort of small battery cage, then I'd really be set.
The pro's and con's vs the Luna pack so far:
1. Cheaper - HD special gave me 2 of these with a power tool for 275. Now these particular batteries are only 2.5ah (vs6) It's all I need with a <5km commute. Versions up to 7.5ah are available.
2. Safer?? - Luna pack has no protection surrounding the battery, and the warnings about it scare me a bit. The EGO batteries are built rugged, and I'm sure could handle a minor drop or two. If they couldn't, I'm sure HD would not take chances selling them. Also nothing against LUNA batteries, I'm sure their quite safe, however I just feel a little safer charging these ones with less likely chance of something going wrong and my house or garage burning down.
3. Quick replacement - Need a new or bigger battery? Defective? Run to Home Depot. Done. Replace it for free from HD in 15 mins! Also a 3 year warranty included!
4. Temperature - I'm going to be using this thing in some cold winters. The luna pack I would have to put some sort of Gel pack around to keep it warm in -20c. The EGO pack will actually detect the temperature and vibrate to warm itself up to proper operating temp first! Also it has some fancy overheating protection built in that converts a a solid protection barrier to a gel or something fancy like that.
5. Colour/size - Ok this thing stands out.. and not necessarily in a good way. The Luna pack is much more stealthy and smaller and fits nicely in this pack I found on Amazon:
(If anyone knows a pack that will fit a EGO battery the same PLEASE let me know!)
I would love feedback if anyone can suggest a proper mounting solution for the back of the seatpost similar to how I have the Luna battery. (I don't want a rear rack mount) Also if anyone would know how to build a proper battery connector/mount for one, that would be amazing!
So why aren't more people running these EGO batteries??
Let me know what you think!
Here's also hoping that Luna battery charger connector will finally arrive :/
-James
-James
