To answer to all questions about if i got one of those new HX motor, the answer is NO
Just looking on these motor, i'm not so impressed...
I dont say they are poor motor!.. but for our great community that OFTEN "overclock" their ebike kit, i doubt that these motor will do the same good job as the old great X5 serie.
Here is my personal reasons:
The new axel look and IS cheaper.. just look at the machining quality of the flat side... it's not precise machining !
The room for phase wires and hall wires is NOT ENOUGH.. you need to make miracle to get 10 AWG wires phase and hall sensor.
Thanks God, i succeded with that miracle on my friend's motor
The heat path between the axel and the stator is not as good as for the X5.. Yes.. the X5 evacuate a bit of stator heat thru the axel !
The metal mass ( 9 pounds of metal removed) add two negative sides: that make the motor sound louder ( szzzzz.. just lik ethe 9C) Dont forget that matal mass contribute alot to damp these sound.. as well as the thick side cover of the X5 do
The 9 pounds removed increase the speed that the stator temp rise... ( big metal mass is slower to heat up)
The old gen X5 never had any stator that make contact to the side cover.. the room between the stator and the inner side of the side cover is enough on the X5.. but too close on the HS serie...
Guess what.. When i pulled the side cover to install the hall sensor.. the side cover bended instead of pull from the axel!!
You will never see that on the X5 old gen !!.. that make me believe that when the wheel is stressed to one side, that these side cover might bend and become a biot off axis and make contact to the stator winding .. ( just under latheral force stress)
BUt... you might all have your own oppinions about that... but after using for 4 years all X5 model, used, new, fast torque, etc, i can say i compare these motor like some of the ICE that love their 457 V8... they are like brute!! and we still love them because they survive over the time!
But.. Once i put my hand on one of those that will be a pleasure to compare it with every of my X5 :wink: .. Dyno.. or on the road !.. and... WITH THE EXACT SAME SETUP AND CONTROLELR SETING AND BATTERY SOC... just for your pleasure :wink:
but i'll not spend a single dollar on these motor...unless i get it for free for review... My next hub motor will be a 5400 serie
.. EXACT SAME DESING BUT MORE POWER CAPABILITY 8)
Doc
