I have owned two hs motors and one x5304. Same bike, 18 fet lyens running 24s3p. 26 inch rim.
The x5 gets about 95km/h wot, the hs hit 110km/h. The x5 can take 10kw peak and about 9k continuous for about 40 minutes; i can run my whole battery to empty at wot if I want, but would certainly burn even the x5 if I was accelerating at wot over and over and over. The hs's I owned saturated at about 8500 watts, and both died doing only 6500 continuous for about 15 mins. To me it seems the hs have thinner guage stator coils, that could contribute, and then the overall stator weight of the x5 also obviously contributes.
I have an old x5 without disk brake covers; it may only be heresay but the pre-disk cover x5 is supposed to be heavier duty then the newer ones. The hs motors I got were in the methods pre buy with the thinner stator, so with a few extra mm of stator you may see slightly better heat sinking.
In the end my gut reaction was that the hs design wasn't up to the power levels I wanted to run it at. Stick to under 6500 watts is my humble opinion. The x5 for sure can take 10kw; i have put about 6000 km on my x5 and it is rock solid, the hs got barely 300km each.
Rapid acceleration builds heat like nothing else. Doing it over and over from red lights on a commute (ie wot from zero) will burn a motor in no time. That same motor could take those peaks all day as long as it's up to speed first. It's all down to responsible power usage.
