I stumbled across these on the Kelly website:
https://www.kellycontroller.com/shop/?mod=cat&cat_id=41,53,56
Their 72v 100A model would be cost competitive with a Castle Creations (but much larger)
They have models up to a 72v 600A model.
Has anyone ever tried one of these? This could be a good solution for the high powered RC drives. It may also be a good solution for the BMC motors that seem to have timing issues when using hall sensors.
Here's what they say about the 100A model:
KSL72100,24V-72V,100A,Sensorless BLDC Controller
Weight: 5 lbs.
Stock: 50 Beta Test Version
KSL controllers are produced for sensorless BLDC motors, especially for fans, water pump, air-conditioning, compressor, etc.
Parameters should be set correctly before use!
Features:
•Intelligence with powerful microprocessor.
•Synchronous rectification, ultra low drop and fast PWM to achieve very high efficiency.
•Current limit.
•Battery current limiting available. Doesn’t affect taking off performance.
•Low EMC.
•LED fault code helps user debugging.
•Battery protection: current cut back, shutdown and warning at high or low battery.
•Rugged aluminum housing for maximum heat dissipation. Rugged connectors.
•Thermal protection: current cuts back on low temperature and high temperature to protect battery and controller.
•Current multiplication: Take less current from battery, output more current to motor!
•Easy installation: 3-wire potentiometer will work.
•Stuck Rotor protection.
General Specifications:
•PWR Supply : 24V-72V
•Frequency of Operation: 16.6kHz.
•Standby Battery Current: < 1mA.
•5V Sensor Supply Current: 40mA.
•Supply Voltage, PWR, 18V to 90V.
•Supply Voltage, PWR, 8V to 30V for controller rated higher than 72V.
•Supply Current, PWR, <150mA.
•Operating Voltage, B+, 18V to 1.25*Nominal Voltage.
•Analog Throttle Input: 0-5 Volts. Producing 0-5V signal with 3-wire pot.
•Reverse Alarm, Meter, Main Contactor Coil Driver: <200mA.( NA*)
•Full Power Operating Temperature Range: 0C to 50C (controller case temperature).
•Operating Temperature Range: -30C to 90C, 100C shutdown (controller case temperature).
•Motor Current Limit, boost current: 100A/50A, depending on model.
•Motor Current Limit, continuous: 40A/20A, depending on model.
•Max Battery Current : Configurable.
Optional Features:
Optional Waterproof : The price is 38 U.S. dollars.
Weight: 5 lbs.
Features:
•Current limit.
•Low EMC.
Optional Features:
