Hillhater
100 TW
Same power yes, but same torque No , because they are designed differently, (winding gauge and turns, + different diameter) and operate in different rpm ranges. 0-4000 rpm for the TS, 0-2750 rpm for the Lb.casainho said:So, correct me if I am wrong: both motors use the same electric power and so both should produce the same torque.Hillhater said:But we are talking about the motor power/ torque.
The gear ratio has nothing to do with the theoretical torque produced by the motor at a fixed voltage and amperage
The Lb has more motor torque.
Which is why they have different reduction ratios
A simple calculation .. Ref..https://simplemotor.com/calculations/
In its most basic form, assuming no efficiency losses..
Motor Torque = Amps * Volts *60 /rpm*2*3.14
If both motors are operating at 750w , 48v , 16 amps
We see for the TS..16*48*60/4000*2*3.142. = 1.83 NM at the motor, or x38 (redn ratio) = 69 NM at the cranks
And for the Lb. 16*48*60/2750*2*3.142. = 2.67 NM at the motor , or x 23 (redn ratio) = 61 NM at the cranks
So different motors, different gearing ratios, same power , gives very similar torque at the cranks.
