Baron
I ordered ten lipo bricks from hobbyking, specifically these ones: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=58976
I'll be using them in a 20S2P config on my bike.
They arrived at around 3.85V per cell. I started putting them on the charger a few hours ago. So far I've gotten through four of them, two have charged/balanced perfectly but the other two have had some problems. For example, one bad pack had the following voltages:
Starting voltage:
3.80
3.81
3.84
3.80
Ending voltage:
3.98
4.03
4.09
3.97
The cells are wildly out of balance in that particular pack. Even before I charged them they were slightly unbalanced.
I'm using the balance function on my charger, an Imax B6 50W. Only charging to 4.10V rather than 4.20. I made sure that all connections are good, you can't really mess it up, there's only + and - terminals and the balance leads.
This is my first time using lipo, but i've used this charger on li-ion 18650 before (in parallel and series configs) without a problem.
So what should I do next?
Contact hobbyking and return the faulty packs?
Try to charge the low voltage cells individually, using the balance leads to isolate particular cells?
Run them through a charge/discharge cycle and see if they correct themselves?
Starting voltage:
3.80
3.81
3.84
3.80
Ending voltage:
3.98
4.03
4.09
3.97
