Kottbullar
Chilehed
Keep up updated as progress continues. This is an interesting thread!
Sorry, I've gotten held up by a number of things so work's been slow. Not quite ready to shoot the color but getting close, I did paint and body work a long time ago and am kinda picky about prep. Freewheel's gotten held up in shipping (stupid USPS stuff). Haven't actually pulled the trigger on a motor yet, I figure patience will allow me to make the most informed purchase I can.Chilehed
Such as? I'm familiar with managing driveline load limits.For real reliable touring range and ability to get there every time, I would avoid mid drives. Too many opportunities for show stopping problems.
I'll think about this, thanks.I think a small lightweight geared hub that cruises at close to your unassisted speed (so probably low voltage rather than high) combined with a 15A controller and a battery with hours worth of full load power, would be a great recipe for cycle touring at cycle touring pace. If you're happy with your speeds and trip durations now, there's no need to add unnecessary weight and cost tooling your bike up to go much faster than you would usually go, at the expense of range.
36V x 30Ah is a little over 1 kWh of battery, and if it's composed of high energy density cells (because specific power demands are low) it need not be very heavy.
Copy that, thanks. In keeping with the counsel of @Az. and @Chalo, I'm composing an email to Whoosh right now.Just an FYI - I have broken a couple of chain rings due to high loads when in my lowest (and most miss-aligned) gear.
Lekkie rings failing on BBSHD
Any one else having trouble with 52T Lekkie rings failing on a BBSHD? I've had two of them fail now both in the same place. The first at about 2,000 miles and the second after another 4,500 miles. I even turned down the amps to 25 after the first one failed but it didn't seem to help much. I've...endless-sphere.com
I'd like to pick your brain about that more if the time comes. I presume part of that includes a battery pack of greater than the 48V they sell with their kits?It is just the sensor. It does not affect power.
Also don't confuse motor rated power with power used by motor (I was totally confused at the beginning).
Motor on my bike is rated 250W (legal limit) and yet I can set it up for well over 1000W
Understood.Not exactly. The trick is to convince manufacturer like Tongsheng or Bafang to put the right sticker on motor they sell. So for example you ask them to put 250W sticker on 750W motor. Why? Because 250W motor is legal and 750W is not.
Some people prefer to buy 750W motor and put right sticker themselves, but it is illegal. Sticker must be put on by manufacturer. As a private person you have small chances for that, but larger distributers are more convincing.
Eventually you can buy just 250W motor and controller which is able to provide 500W or 750W and hope you wont burn motor. There is no legal limit on amount of power used by controller.
PS I use standard 48V battery I bought from PSW
I think some more specificity on the grades, length, and your required speeds for the climbs would help narrow it down. For example:What's available that fits that? Remember, my rides include pretty hefty grades that go on for miles. On return trips I can coast at well over 20 mph for a solid half hour.
Fair enough. One of my favorite rides has a 2,000 foot climb over 12 miles: 4% for several miles, 6% for one mile and a 30% grade for a couple of hundred yards (not kidding: it's up the driveway leaving my FIL's house and usually I'd make it less than halfway before walking it. Tough way to warm up!).I think some more specificity on the grades, length, and your required speeds for the climbs would help narrow it down.
Damn! 8 miles at 8%? Turns out I'm a piker! Sounds like more than enough motor for me, but being Bafang it's cadence sensing, right?I've got a bikepacking setup utilizing a gravel setup that usually carries around 25~30lbs when loaded. It has a front Bafang G310 motor (around 6lbs. dressed) in a 584 rim. I'm a pretty weak rider with only a ~220W FTP, and up climbs while touring, I'm typically at about 150W at the cranks. With the G310, climbing a mild hill (e.g. 4% for 2 miles) with 500W to get up the hill quickly works fine, while climbing a more serious hill on my way to Santa Cruz (8 miles at 8% average) limits the continuous motor power to around 150W (mechanical output) in order to not exceed a comfortable motor temperature (90°C) for longevity. That puts the climb time in line with enthusiastic club riders.
Will do.On the topic of motor ratings, you may want to read Justin L.E.'s rant on the topic.
Will do.
How would a front hub motor sense torque? You normally sense the pedal torque at the bottom bracket. That signal is fed to some control circuitry that then sends a throttle command to the motor controller. You can use any motor with torque sensing. For instance, I used the Cycle Analyst and the Fischer AG Torque Sensing Bottom bracket they currently have on sale for my cargo bike. It uses a Stoke Monkey mid-drive, but the torque sensing could be applied to a front or rear hub motor just the same.I'm coming up blank trying to find a torque sensing front hub motor in the States. I'm glad I fixed up my Cannondale, but it's really looking like it's not the best pick for an ebike build. Time to rethink.
Well, yes, I was being lazy and didn't want to tap out "torque sensing BB and geared hub motor that I can fit into my narrow spacing" on my phone.How would a front hub motor sense torque?
Thank you!...Fischer AG Torque Sensing Bottom bracket they currently have on sale...
I think I'd prefer it as well, but I've gathered that my 110 mm freewheel hub poses some issues and I don't want to risk trying to widen the frame. I just emailed Grin.And not that you asked, but I'm inclined toward having the hub motor on the rear wheel unless there is some strong reason not to.
What the... ??!? How the FRICK did I look at it so many times and still manage to get that measurement wrong? You're right, it's 126mm.Isn't it 120mm or 126mm on the back?
I just thought it looked like I'd like it better than the other options, and it was only $25 at VO so I figured it was a cheap experiment.Yes, ski season is coming up. That's when I get my best project work done!
Watching your progress, I'm a few steps behind you. Am thinking Jones bar instead of butterfly or others. What made you to Butterfly?
