CONSIDERABLE SHOUTING
- Joined
- Jun 15, 2019
- Messages
- 815
I snagged a "Brainpower Motor Controller" for a couple of dollars awhile ago and I've been steadily working my way to building a junker eBike, but I'm having difficulties tracking the wiring and plugs they use and how to best take advantage of what the controller can do. I've found it's listing in multiple Amazon listings, but some of the details are missing key things and I was hoping you guys could recommend specific parts or what the voltages tend to be for things like rear break lights. It has the little display shown in the image too, but I'm not yet sure what it shows.
Amazon Listing 1
Amazon Listing 2
Amazon Listing 3
Thankfully it seems to be very common, but as you can see from leafing over the images presented they have some odd descriptions for different parts. I'm looking for help (and part recommendations) for these things:
- 6km/h assist- might also be cruise control, but mine has a grey wire and not blue. Not sure how to use that at all.
- Low potential brake - Other pages call it a "Throttle" and "Speed steering handle"; 3 speed switch? ]This one seems to be the cheapest.
- Lamp power - No description of voltage. Should I just assume it's at battery voltage? Other guides claim it's on a circut with the "Brake Power off" clips which I know would go to my brake levers; I'd rather not spend more money on new brake levels for the circuit, but my city wants a rear light (which I might have) and I don't think I have momentary switches that can run this voltage.
- Intelligent identification
- 1:1 assist - PAS sensor? This one looks just fine to use.
- Power- I'd like to replace this with a switch, but I could also do an XT loop. Do they likely run the same voltage as the battery?
- Finally, are there any provisions on the controller where I could tap a headlight? Or should I just run a separate one?
The controller can run at 36 or 48 volts, and I intend to run 48 volts. It's cutoff is 42, so I can't use the cheap samsung batteries HERE like I wanted to, but Battery clearing house has some big ones at 48 volts that might be worth a look. Current is limited to 13 amps, and I'll be using a Jumpbike hub that was bought from BCH. I plan to run it front wheel on a 29" BSO I got for $8 from a junkyard that is full suspension.
Thanks for any input you have!
