boostjuice
I just thought i would let people know that Cyclone http://www.cyclone-tw.com/order.htm have recently added 3000Watt (4329Watts peak) motor kits to their existing product line which they claim can achieve speeds up to 90kph (54Mph). Interestingly the buyer has the option of purchasing them with or without the recommended Kelly 48V 75A KEB48300 controller, a move away from the universally adopted 'Headline-Motor' controllers offered for all other models.
I just think every power hungry e-biker should throw this option into the equation of choice when tossing up between an overvolted 2kw+ Crystalyte X5 or a 3kw+ RC style BB-drive/direct-drive system. Although I'm all for RC motors which have the obvious weight/efficiency advantages, this other option of heavier/high power/lower RPM motors require less reduction and so can be made to work without the need for such a complicated gearbox that the RC motors require. In other words, they can be a bit easier to setup compared with the elite RC drive that Matt is working on, but obviously more difficult than a hub motor.
Ive personally coupled my motor to a bevel-helical gearunit that not only reduces the high rpm with only a 6% power loss, but as power exits the box 90degrees offset to the motor shaft, the long barrelled motor can be mounted in line with the frame tubing (refer to my avatar). This removes the need for an extended bottom bracket spindle that has you pedaling like a bow-legged cowboy (my main complaint with the standard cyclone kit setup)
I confirmed with "Paco" (Cyclone sales rep) that the 3kw version uses the same casing as the 1kw version. This achievement is no surprise as when i opened up mine to inspect the internals of my 1kw version, only about half the casing length is filled with magnets/windings. Plenty of room for increased power. EDIT - on further discussion with "Paco", the 3kw motor is physically identical to the 1kw motor, it is only the more powerful controller that warrants the advertised power increase.
As an owner of the 1000watt kit i can say that despite design/quality problems with many components in the kit, the motors are very good quality with great performance. I get a flat ground top speed of 59kph (35mph) through my BB drive system.
Its interesting to note that the motors and controllers are manufactured by "headline-motor Taiwan"http://www.headline-motor.com/main_e.htm which are then on-sold by Cyclone with their added lower quality components. Unfortunately, when i emailed them, Headline-Motors were not interested in selling small quantities directly to e-bike users, preferring to deal with large scale commercial orders only.
The 1000Watt motor has rated continuous 83.46Kg-cm (~8.2Nm) of torque at 2200rpm. When geared down for a BB drive cadence of 75rpm, this equates to 240Nm of torque at the crank, or ~72Nm of torque at a 250rpm wheel speed (~30kph/ 26" rim) in a direct drive system. This is pretty impressive! especially when compared with the usual competetor, a brushed MY1020 48V 1kw Unite motor that offers only around 3.2Nm max in their peak torque zone. http://www.cn-dcmotors.com/productShows.asp?ArticleID=276
Cyclone Dynometer plot 1kw
Cyclone have a patchy/incomplete website, so torque figures/dyno plot for the new 3000watt motor haven't been listed yet, but they do quote 3000Watt (4329Watts peak), whereas the 1000watt motor draws peak watts up around 2400Watts.
Anyway, i just thought id let people know about them due to my success using them.
Cheers
Cheers
