MTH07
I am new to battery building, and trying to make sure that I am thinking through my first battery build to power my BBSHD powered ebike.
My question is on sizing of the nickel strip connections - I am looking at using samsung 25r cells in a 14s4p configuration. The controller on the BBSHD is 30 amps. I figure on using a 40A BMS so there is a little margin of error there above the 30 amps that the controller could demand.
I know that there are higher capacity cells that would give me a higher capacity in that configuration, but I am leaning towards the 25r cells for this first build due to the lower cost and they are likely to run nice and cool no matter how hard I flog the bike.
Since those cells are 20A cells, the battery would be theoretically capable of producing up to 80A, but it would be limited by the 40A bms. Do I need to size the series connections for the maximum theoretical possible (e.g. 0.15mmx8mm strips at 5A each for a total of 16 strips needed), or the BMS limitation (8 strips needed)? If I need to accomodate the full 80A, I probably need to look at other options like nickel/copper sandwiching etc. If I can get away with 2 strips per connection, I will probably just go with relatively thin pure nickel to keep things simple, but I don't want to create an unsafe condition obviously.
Thanks in advance for any insights on this!
