ArthurH
Hello, I've been lurking for a while but decided to take some pictures since I had to bring it in for a nasty puncture repair. This is my first functional ebike. I've got a nuvinci hub to go on it when my new rims finally arrive. May strip and paint the frame too.
Frame with some components purchased from The Pedal Depot in Vancouver BC summer 2013. The next summer I swapped the Ezee hub (used) with a friend for a new Rhyno Lite rim, fixed a dead controller (5V regulator failed) and replaced one of the BMC balancing transistors which had failed in a short. The battery pack is not doing so well, I'm getting maybe 6Ah if I baby it.
The rear lights are from Grin Tech. I'm using the turn signal wiring on the outside lights, center brake light power is wired to my ebrake lever (geared front hub means no regen short of some major modification so it's just a brake light for now).
Awesome forum folks, best luck on your builds.
cheers,
Arthur
cheers,
Arthur
