inedible said:Got around to taking one of these apart today, took some nice high res pictures of the process.
My goal was to leave the corners intact so the stack of modules can still be bolted together. So, unlike others, I left most of the can intact, just opening it enough to get at the tabs.
Here's a link to the album: http://imgur.com/a/ULQfj
I'm happy to say I didn't explode at all. Not even a bit.
inedible said:Can anyone tell me what gauge of wire I should use to connect the cells?
I see in his videos that user mvly used two strands of 14awg between each cell, and said in theory 1 strand of 14awg is enough, but I'm not sure that's right. Why do they have such thick solid copper bus bars between the cells in the original configuration? Surely that's there for a reason.
I've only got 20awg laying around. I was thinking of using three or four strands or something, but what do you think? Am I better off buying some 12awg between the cells, maybe some 8awg for the main output?
I don't even really know what amperage my motor is pulling. It's rated at 500w, 48v, so that ought to mean it's using ~10A, yet my controller says 40A on it. The existing wires going off my stock 48v SLA battery are like 12awg I think.
mvly said:Well 4300 miles and over 130 cycles so far at 1-2C discharge and much slower C charging and still going strong. It sags more now, but still gives the full 25Ah I was getting when I first got them used.
I don't think these are great for large C discharge. Too much sag and probably not good for the battery. If these were indeed put in power tools, I can see why they would not last long. That would be Milwaukee's failed engineering, not the battery chemistry itself.
MN Driver said:mvly said:Well 4300 miles and over 130 cycles so far at 1-2C discharge and much slower C charging and still going strong. It sags more now, but still gives the full 25Ah I was getting when I first got them used.
Can you quantify the sag? What voltage are you dipping to and what amperage for that voltage? I'm trying to get an idea of how bad these really are. Especially considering large format LiFePO4 like CALB sag to 2.889v with a 30 second 576 amp 8C draw on their 72Ah cells with a resting voltage of about 3.3v. I'm wondering if these Leaf are really only the budget conscious option to take.
I have a LEAF, and the motor pulls 80kW+ at full throttle, so that is over 3C. Voltage does appear to sag pretty significantly, I'll try to get some data.mvly said:I am not sure if the LEAF cells are good for more than 2C current draw. I have not tested it yet, but I suspect it will sag quite a bit.
drees said:I have a LEAF, and the motor pulls 80kW+ at full throttle, so that is over 3C. Voltage does appear to sag pretty significantly, I'll try to get some data.mvly said:I am not sure if the LEAF cells are good for more than 2C current draw. I have not tested it yet, but I suspect it will sag quite a bit.
Nissan does not limit power until well after the cells have lost 30% capacity - don't know if anyone's gotten them to lose much more capacity than that. Keep the cells as cool as you can, they don't like the heat. They'll sag more in the cold, but work fine down to freezing temperatures. Nissan heats the pack if they get down to -4F and then turns off the heater when the pack reaches 14F. Discharging is fine at high rates when cold, but be very careful charging when temps are below freezing.
What voltage limits are you using? Nissan shuts the car down when the resting voltage gets just above 3.0V resting voltage, 80% "long life" is around 4.02V / cell and "100%" is just over 4.1V / cell (all resting voltages).
Yes, I think it's a good idea to limit your voltage a bit more. It will reduce your usable capacity now, but it should improve it down the road. How much imbalance are you seeing at lower SOC? Nissan also top-balances the pack. When charged to 100% balance is typically around 30mV or better ('13+ LEAFs seem to keep balance better), but as you note, once resting voltage gets down to 3.6V you can see 100mV difference. The pack is nearly fully discharged then, anyway.mvly said:According the specs of the battery, full charge is 4.2V. However I am not aware of the 4.1V 100% capacity. The voltage does drop relatively fast from 100.3V to around 98V-99V just after 0.25Ah usage. It's good to know I should charge it to lower limits.
I use mine from 4.17V full charge down to 3.7V at the lowest. I took it down to 3.0V average at idle once, but the cells were all imbalance. I would keep these cells above 3.6V idle.
Common procedure for determining peak discharge rates is to do pulse discharges until the lowest cell reaches a minimum voltage, typically 2.5-3.0V or something. I think NREL testing showed that the LEAF pack will do 200 kW pulse discharge across most of the SOC range, that's around 8C. Of course, it won't do that very long. You should be fine at 3-4 C for pulse discharge rates, just don't let the cells drop below 3.0V. But then again even Nissan lets the cells drop below 3.0V under load at low SOC.mvly said:AI think I did a quick calculation on this discharge stuff and concluded these cells can handle up to 5C burst if their specs were correct. Though I would think the sag at those current rate is pretty bad.
drees said:Yes, I think it's a good idea to limit your voltage a bit more. It will reduce your usable capacity now, but it should improve it down the road. How much imbalance are you seeing at lower SOC? Nissan also top-balances the pack. When charged to 100% balance is typically around 30mV or better ('13+ LEAFs seem to keep balance better), but as you note, once resting voltage gets down to 3.6V you can see 100mV difference. The pack is nearly fully discharged then, anyway.
I can't tell you how much of a difference in cycle life it will make going well above 4.1V, I can only tell you what Nissan does with the cells.mvly said:Are you sure I should only charge to 4.1V? I checked the battery specs and it states 403.2V max. This is 96 cells in series charged to 4.2V each. Nominal is 360V which correspond to 3.75V per cell.
Heh, I don't keep it at 4.17V for long anyways. I usually charge to full and within 1-2 hours I ride. So i guess it doesn't really matter. The rest of the time it's mostly around 3.95V
do you have a reference to those CalB tests ?MN Driver said:Especially considering large format LiFePO4 like CALB sag to 2.889v with a 30 second 576 amp 8C draw on their 72Ah cells with a resting voltage of about 3.3v. I'm wondering if these Leaf are really only the budget conscious option to take.
Hillhater said:That is implying an IR of less than 0.001 ohm, which is much less than even the Nanotec lipo cells !![]()
http://endless-sphere.com/forums/viewtopic.php?f=14&t=58210&p=906009#p906009
Or am i missing something here ?
Skip to 1:17:30. Pay attention to the time he actually turns the load on and count 30 seconds because he actually runs out about 40 seconds or so.Hillhater said:do you have a reference to those CalB tests ?MN Driver said:Especially considering large format LiFePO4 like CALB sag to 2.889v with a 30 second 576 amp 8C draw on their 72Ah cells with a resting voltage of about 3.3v. I'm wondering if these Leaf are really only the budget conscious option to take.
