okashira
Arlo1 said:What voltage does it run?okashira said:Cool, thanks.
I need to get measuring the spark ev motor. I am afraid how low it might be
I would not worry![]()
Same 400V. But should be good for 800V I think
Why would you try to run such high voltage? The lower the better.okashira said:Arlo1 said:What voltage does it run?okashira said:Cool, thanks.
MPaulHolmes said:Bowser, no updates from my beta testers. The one with the Leaf motor is getting little details worked out like ordering a hall effect throttle. Well, one update from my beta tester in Canada. He's gotten his controller up to 360amp (phase current). He has it hooked up, fighting a big AC motor against a DC motor. He'll be visiting my house down here in Arizona today. I'm building him a 1400amp 350vDC controller, so he can properly test the AC controller on that dyno setup. I already have 3 beta testers with the DC controller, and it has worked great for the last couple years. I can't believe it has already been 2 years, and I haven't done anything beyond the 3 beta testers. Oh well.
The neat thing is, the power section for the AC and DC controllers are IDENTICAL. Even down to the 3 phase cables and 3 individual current sensors, and 3 individual hardware overcurrent circuits (one for each IGBT module. you can't assume that just because the IGBTs are paralleled, that they are passing the same currents). The only difference is, you hook all 3 phase cables together, and attach it to the DC motor. A cool trick is to make the 3 "phase" cables a few feet long in the case of the DC motor controller. It forces the IGBT modules to current share better.
So, you just plug a DC board into the 3 600v 600amp IGBT modules and drive a DC motor at 1400amp 350vDC, or you plug the AC board into them and drive an AC motor with about 350vDC 400ampRMS.
I have the perfect capacitor for an 800v 600ampRMS controller:
http://www.sbelectronics.com/product/power-ring-777d114-1500-uf-900-vdc-ul-recognized/
One of those, and 3 1200v 800amp half bridges would be awesome.
Arlo1 said:The OEMs reduce phase current as rpm increases to save the battery so get a KV measurement and do the math. You might be surprised.
MPaulHolmes said:Here's the Nissan Leaf motor guy getting his home made dune buggy race car running! He's using 200v worth of a Chevy volt battery pack, and had set the phase current to 300amp peak for this test:
https://www.youtube.com/watch?v=qUioVe_Z8is&feature=youtu.be
MPaulHolmes said:Well, the 6 pwms are square waves, but it all ends up looking like current sine waves due to the stator inductance. What is your switching frequency? For my DC controller I'm using spread spectrum 7-12kHz (it sounds like rushing water!). For the AC, I'm using 10KHz. According to the datasheet the cap can do 500amp continuous, which would be 200kW with a 400vDC bus. So far, it appears at high current that Id and Iq are tracking IdRef and IqRef very well.
Interesting. We thought that Leaf used 10kHz. Do they go 6-step at high rpm or torque ?Arlo1 said:I set mine up at 5khz. I chose that number because that's the number Nissan used and I designed mine to run up to 20khz but 5 is more efficient.
NeverMPaulHolmes said:Okashira! haha Yes that's right. Have you ever just typed something without thinking first? I never do that. ever. lol.
Hi paul I was just looking at this to see if I work math the same way. And more or less I do. Other then 1 thing I have a problem with. You say each IGBT would be 565/2 = 283 amps then at the bottom you say each igbt would be 433 RMS for a 300kw setup. How do you arrive at this number? Are you running 6 half bridges? 2 in parallel per phase?MPaulHolmes said:Man, I'm not getting updates to the thread. Sorry it took so long to get back. I just randomly checked today. I know the Leaf motor is very conservatively rated at 80kW continuous. I have been busy with my job, and I haven't heard from the Leaf guy (andrew) in a little while. My beta tester in Canada tested the controller to its hardware overcurrent trip point of 600amp (peak) phase current in this video. His is a 3/8" aluminum plate with no water cooling and no fins, so it heats up:
https://www.youtube.com/watch?v=8dS1CPcZaec&feature=youtu.be
Also, the power of the controller (with liquid cooling) is conservatively 200kW. The RMS phase current could easily be 400amp. To see that, the peak phase current would be 400*sqrt(2) = 565amp, and that means that the RMS current of each IGBT would be 565/2 = 283amp (square waves, which are on average 50% duty). They are 600amp IGBTs so that's more than 50% derating. Now, assuming 400ampRMS current and battery pack of 400v the power would be:
power = line to neutral peak voltage * line to neutral peak current * 3/2 =
= battery pack /sqrt(3) * rms phase current*sqrt(2) * 3/2 = 196kW
I've heard that the peak power of the Leaf motor is more like 300kW. I think the controller could do close to 300kW for short accelerations. Well, let's see:
300kW = 400/sqrt(3) * rms phase current * sqrt(2) * 3/2
So, rms phase current = 3k/4*sqrt(3)/sqrt(2)*2/3 = 612amp.
So, peak phase current = 612 * sqrt(2) = 865amp, so the RMS current per IGBT would be 433amp. That's almost 2/3 derating still! So, I bet with water cooling you could do short 300kW accelerations with the leaf motor.
