hi, newbie here, been reading this great site for a long time but now first post for help.
I have a self made trials bike - low speed torque is more important than milage - I get 45 mins at the moment, which is ample, as I use it in the back yard.
I have a 1000 watt brush motor on 48v - this is mounted to a five speed gearbox, in turn mounted to the rear wheel via a big cog.
the system ran great until my 1000 watt controller, packed in on the throttle connections. So I got a new unit - supposedly heavy duty at 1500 watt to replace it.
the old unit only had 5 mosfets, barely any solder on the circuits for amps, yet still was very good.
Imagine my disappointment when the new supposedly bigger controller is much lower powered through the system - about 50% lower. I decided that it must be the way its programmed and decided to open it up and modify the shunt - dead easy!.
So I opened it up, the components are much heavier duty, lots of wire in the solders tracks to carry amps etc - but no shunt to modify?
Does anybody recognise how it works and how to modify it? Is it using the 2 large resisters as a shunt? Im an electrical idiot so plain English for any replies, many thanks.
jed
jed
