no throttle on my gio scooter
lwontca
10 µW
hi i was riding my scooter and hit a pot hole and then i had no throttle. I pushed it for a bit then i bounced on it and it started going on its own no throttle control at all. Once i got it home and turned it off then tried it again nothing just lights horn signals and dash board.
Any ideas thanks
Probably the throttle itself, or it's connection. Could be a magnet came off inside the throttle, and is no longer activating teh hall sensor right.
To prevent this in the future, i recommend the following.
Upgrade to 132v of lipo straight up.
Purchase a lyen controller.
Upon seeing the pothole, pop the scooter up on its back wheel by going WOT an clear the hole in an evil kenevil style manner.
Pull over and bitches will come.
discclaimer - bitches coming may or may not be grossly inaccurate.
hi can anyone tell me how to power up my motor on my 500 w gio so i can make sure it works. what wire should i put power to to make it go
thanks
thanks
How many large wires do you have coming from your hub motor? Two, or three?
Then it is most likely a brushless 3-phase motor, and you must use a brushless controller to run it. If the one on the scooter is not working, you could use an external one to test it. I would first check with Lyen here on ES for a tester, though, as that will help you figure out what the problem part is.
