Can u do the star delta switch on the fly? I think u don't have a switch u said. So what kv are u now?
What are the bearings against? And all pressed or slide? What's the sk3 use?
U say bearings pressed into steel and then how does that go into the aluminum? Press?
I like pressed bearings. It's how they're supposed to be done. On steel. So ur motor uses the skate shaft as the motor shaft w skate bearing?
