Alan B
Easiest thing is to get one of the FTDI cables. USB on one end, TTL serial on the other (both 3.3V and 5V models available). Signed drivers on their website. Digikey, Sparkfun, Amazon, etc have them. Great for serial to USB projects.
So I guess the first thing is I have to scope it. And see but its not likely they would step it up to 12v if I have a usb thats only 5 and all it needs is > and < 3 volts!GMUseless said:RS-232 is actually +/- 3-15v. Less than 3v is 0, greater than 3 is is 1. Early on most PC's used 12V, so that became common. These days, many devices use 5v. USB is 5V, so your convertor is most likely 5v RS-232.
Arlo1 said:Ok guys i used the curcuit scematic that bigmoose presented and i see alot of others use another chip between the main chip and the rs232 so im wondering can i just run the dspic30f3010 to my rs232 header with the apropriate caps and resistors?
texaspyro said:I have not used a simulator or debugger in ages. They are far more trouble than they are worth (particularly simulators, which NEVER seem to get it right). I have found it to be much easier to just write perfect code without any bugs in it![]()
I eat the elephant one byte at a time. Start with a very minimal program (like "Hello World") and build your application up in very small increments. I use print statements to find out what is and is not happening.
pelle242 said:About #2. In brief you first need to connect the pot to one of the AD inputs and ensure that it varies to voltage from 0 to 5 volts (or whatever your Vcc is). Then you have to set up the AD hardware inside the chip to use the pin as an AD (one pin can usually be programed to do several different things) This is done by writing values to specific memory locations (called peripheral registers). What addresses this registers have and what the specific bits in the registers do is in the big datasheet for the device you are using. The might also be some code from the vendor (microchip in this case) that you can build on to make it easier for you.
Once everything is configured right there will be one or two registers you can read to get the actual value of the voltage at the pin. If it is a 8 bit resolution converter you will get values from 0 to 255 for a 10 bit you will have to read two register and together they will form value from 0 to 1023.
To flash the LED there is the good way and the quick and dirty way. The quick way would be to set up a timer peripheral to generate interrupts and vary the timebase based on the AD value and then write an interrupt routine that will flash the LED.
The simple way is to write a "busy loop" function (it is called busy since the cpu cant do anything else during the delay) and the number of loops is based on the AD value.
Your program would be like:
Code:void busyLoop(int loops) { volatile int i; for(i = 0; i < loops; i++) {} } void main(void) { unsigned int val; setupAD(); setupLED(); while(1) { ledOn(); val = readAD(); busyLoop(val); ledOf(); busyLoop(val); } }
Please note, this is just from the top of my head, I have never coded C for dsPIC but the basic principle is the same regardless.
All the gritty details are in the functions that you have to code yourself or "steal"![]()
#define "p30F3010"
#include "p30F3010.h"
//Configuration bits
_FOSC(CSW_FSCM_OFF & XT_PLL4);
_FWDT(WDT_OFF);
_FBORPOR (PBOR_OFF & PWRT_16 & MCLR_EN);
_FGS(CODE_PROT_OFF);
//Program Specific Constants
#define FCY 7372800 //Instruction cycle rate (Osc x PLL / 4)
//Main routine
volatile int i;
void main(void) {
unsigned int val;
ADPCFG = 0xFFFB; // all PORTB = Digital; RB2 = analog
ADCON1 = 0x0000; // SAMP bit = 0 ends sampling ...
// and starts converting
ADCHS = 0x0002; // Connect RB2/AN2 as CH0 input ..
// in this example RB2/AN2 is the input
ADCSSL = 0;
ADCON3 = 0x0002; // Manual Sample, Tad = internal 2 Tcy
ADCON2 = 0;
ADCON1bits.ADON = 1; // turn ADC ON
while (1) // repeat continuously
ADCON1bits.SAMP = 1; // start sampling ...
DelayNmSec(100); // for 100 mS
ADCON1bits.SAMP = 0; // start Converting
while (!ADCON1bits.DONE); // conversion done?
ADCValue = ADCBUF0; // yes then get ADC value
} // repeat
MOV 0xFF00, W0; // configure port B as imput
SetupAD()
LATD = 0xfffe; //Initialize LED pin data to off state
TRISD = 0xfffe; //Set LED pin as output
LATDbits.LATD0 = 1; //Turn LED on
while(1) {
TRISD = (1);
busyLoop(val);
TRISD = (0);
busyLoop(val);
Arlo1 said:Arlo1.c:1:11: error: macro names must be identifiers
No " on macro names.
Arlo1.c:22: warning: return type of 'main' is not 'int'
As the man says, main return type must be int (you have it void)
Arlo1.c: In function 'main':
Arlo1.c:38: warning: implicit declaration of function 'DelayNmSec'
Means it doesn't know about it, maybe wrong name or missing header file.
Arlo1.c:41: error: 'ADCValue' undeclared (first use in this function)
You have to declare your variables (before usage). That's basic C, you need to read half of a C book's chapter on variables.
Arlo1.c:41: error: (Each undeclared identifier is reported only once
Arlo1.c:41: error: for each function it appears in.)
Arlo1.c:43: error: 'MOV' undeclared (first use in this function)
Arlo1.c:43: error: syntax error before numeric constant
Arlo1.c:44: warning: implicit declaration of function 'SetupAD'
Arlo1.c:45: error: syntax error before 'LATD'
You need to terminate your C instructions with a ;
Halting build on first failure as requested.
void main(void) {
unsigned int val;
ADPCFG = 0xFFFB; // all PORTB = Digital; RB2 = analog <-- Put in setupAD function
ADPCFG = 0xFFFB; // all PORTB = Digital; RB2 = analog <- this also
ADCON1 = 0x0000; // SAMP bit = 0 ends sampling ... <- and this
ADCHS = 0x0002; // Connect RB2/AN2 as CH0 input .. <- and this
ADCSSL = 0;
ADCON3 = 0x0002; // Manual Sample, Tad = internal 2 Tcy <- and this
ADCON2 = 0;
ADCON1bits.ADON = 1; // turn ADC ON <- until here i guess..
ADCON1bits.SAMP = 1; // start sampling ... <- Should be in a getAD() function
DelayNmSec(100); // for 100 mS <- replace with busyLoop();
ADCValue = ADCBUF0; // yes then get ADC value <- ADCValue is a variable, must be devlared in the begining of function. Replace with val.
} // repeat <- until here
MOV 0xFF00, W0; // configure port B as imput <- need to go, replace with C code.
SetupAD() <- needs a ;
LATD = 0xfffe; //Initialize LED pin data to off state <- put into initLED() or initIO() function
TRISD = 0xfffe; //Set LED pin as output <- this also;
LATDbits.LATD0 = 1; //Turn LED on <-
while(1) {
TRISD = (1);
busyLoop(val);
TRISD = (0);
busyLoop(val);
ADCON1 = 0x0000; // SAMP bit = 0 ends sampling ... <-- The cpu will never get down here, it is looping above.
ADCSSL = 0;
ADCON2 = 0;
} // repeat
SetupAD()
while(1) {
TRISD = (1);
busyLoop(val);
TRISD = (0);
busyLoop(val);
void InitADC1(void)
ADC Initialization: For correct A/D conversions, the A/D conversion clock
(TAD) must be selected to ensure a minimum TAD time of 153 nsec
10 bit 1 in 1024 resolution
void InitADC1(void)
ADPCFG = 0xFFF8; // port configuration RB0 to RB2 = analog
//ADCON1 = 0x0064; // PWM starts conversion, auto sampling
ADCON1 = 0x0044; // TIMER3 starts conversion, auto sampling
//ADCON1 = 0x00E4; // Autoconvert starts conversion, auto sampling
ADCON2 = 0x0000; // sample CH0 channel only
ADCHS = 0x0002; // Connect RB2/AN2 as CH0 = pot.
//ADCON3 = 0x0080; // Tad = internal RC clock (4uS)
ADCON3 = 0x0005; // Tad=153nS rqd ADCS=306/Tcy -1
IFS0bits.ADIF = 0; // clear ADC interrupt flag
IEC0bits.ADIE = 1; // enable ADC interrupt
T3CONbits.TON = 1; // start TMR3 to start ADC conversion
#define "p30F3010"
_FWDT(WDT_OFF);
//Main routine
int main(void)
PORTDbits.RD0 = 1; // alternate way
unsigned int val;
ADC_Init(); // Init ADC
while (1)
ADCON1 = 0x0000; // SAMP bit = 0 ends sampling and starts converting
ADCHS = 0x0002; // Connect RB2/AN2 as CH0 input in this example RB2/AN2 is the input
ADCSSL = 0;
ADCON2 = 0;
return ADRESH; //// return high byte of result
while(1) //Loop forever
Release build of project `C:\Program Files (x86)\Microchip\Tps Led.mcp' started.
Language tool versions: pic30-as.exe v3.30, pic30-gcc.exe v3.30, pic30-ld.exe v3.30, pic30-ar.exe v3.30
Thu Dec 15 22:15:14 2011
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.30c\bin\pic30-gcc.exe" -mcpu=30F3010 -x c -c "Arlo1.c" -o"Arlo1.o" -g -Wall
Arlo1.c:14:1: error: unterminated comment
Release build of project `C:\Program Files (x86)\Microchip\Tps Led.mcp' failed.
BUILD FAILED
Not understanding the macro names yet.
Njay said:Arlo1 said:Arlo1.c:1:11: error: macro names must be identifiers
Njay said:Njay said:Arlo1 said:Arlo1.c:1:11: error: macro names must be identifiers
Awesome thanks. I got rid of that one. It was that way I had incl # define "p30f3010" switched it to # define __p30f3010__ Only one problem left to solve. And add the rest of the code.Alan B said:Just to expand on that,
in source file Arlo.c, line 1, column 11, macro name was expected but " was found instead.
A define is a macro, and macro names cannot start with the double quote character.
I started with the pic kit lessons, then got the dspic30f3010 set up and got a LED to flash. So I feel after getting a LED to flash it would make sense to get it to flash at different speeds with a throttle. I want to learn the code I need for now all pertaining to a motor controller.Lebowski said:I must admit I started much simplerMy first program on a new processor typically
makes a light connected to one pin go on when I press a button connected to another pin.
The second program I try to get the RS232 to transmit something, it's easy to see on a scope
whether there's activity on the TX pin.
#define __p30F3010__
#include "adc10.h"
#include "delay.h"
_FWDT(WDT_OFF);
//Main routine
//Main routine
volatile int i;
int main(void) {
unsigned int val;
while (1)
ADCSSL = 0;
ADCON2 = 0;
return ADRESH; // return high byte of result
Clean: Done.
Arlo1.c:32: warning: implicit declaration of function 'ADC_Init'
Arlo1.c:34: error: syntax error before '}' token
Arlo1.c:31: warning: unused variable 'val'
Arlo1.c:44: warning: implicit declaration of function 'DelayNmSec'
Arlo1.c:47: error: 'ADCValue' undeclared (first use in this function)
Arlo1.c:47: error: (Each undeclared identifier is reported only once
Arlo1.c:47: error: for each function it appears in.)
Arlo1.c:48: error: 'ADRESH' undeclared (first use in this function)
Arlo1.c:50: error: syntax error before '}' token
Arlo1.c:51: warning: control reaches end of non-void function
Fri Dec 16 07:42:46 2011
BUILD FAILED
