bl4s7er
10 µW
- Joined
- Oct 25, 2017
- Messages
- 5
So, I have decided it would be fun to build an ebike! This might get a little long winded but I want to provide as much info as possible so ppl can offer valid feedback. I think I am just about there so here goes;
A couple of months ago I realised I was pretty unfit and I also remembered how much fun I had on my bike in my younger years (I practically lived on it). Looking at buying one the first shock was how expensive bikes are these days. Maybe they always were?. So I started looking at 2nd hand. I came across a pretty good deal IMO - $200 for a 2003 Giant NRS 2. But it needed some work..
I turned it into a rebuild project and stripped it down to the last bolt and bearing. Ended up spending another $300 on parts including new tyre and shimano SLX-M675 hydraulic brakes and rotors.
So now I have a nicer bike than I could have bought off the shelf for the same money (I hope!) and I learnt a lot through the process.
So with my bike finished I took to the streets. I get out 5 days a week minimum and end up doing 10-13km in 30min (avg ~22km/h). On the flat without a headwind I can maintain +30km/h. And with a tailwind can push to 40km/h. Top speed (cadance/gearing being the limiting factor) was 54km/h down hill. I have only been on the bike a month now so expect to be able push a bit harder as I go along.
In the back of my mind I was always thinking of converting to an ebike which is why I specifically looked at a MTB - stronger frames and shocks to smooth the ride. The reasoning behind this is to extend the range I can go thus increasing the enjoyment of riding in new areas. I get bored doing the same paths over and over! This opens up opportunities to head out somewhere new (with PAS), have a ride (without assist) and then head back. I will have to be disciplined to make sure I dont become reliant and actually do put in the effort! I may even consider riding to work (25km).
So the main criteria I believe meets my requirements;
- I still want to exercise
- I want to limit additional weight
- I have a limited budget (cheap is good but not so cheap that its likely to fail)
This is where I am at based on the above;
- Q128C 36v 201rpm @ 48v (or 52v?)
(DD resistance and weight doesnt appeal so thinking geared options are best)
- pswpower KT-LCD3 + SW controller (17A or 20A?)
- 26" x 21-24mm Rim (still looking at options.. )
- Schwalbe Energizer Plus tyre (I already have one installed on the front)
https://www.schwalbe.com/en/tour-reader/energizer-plus.html
Lastly.. batteries
Based on the above I dont know if I can push it to 52v or should I stick with 48v?
I am also not sure if I should go with 4p or 5p
using these cells - LG INR18650MH1 3200mAh - 10A, so between 52 to 70 cells depending on output that is recommended.
I am thinking that a triangle battery case would be better as opposed to a dolphin case?
Lastly, I am looking to purchase batteries 1st, build and test before getting everything else. That way I have a working pack to test everything else when it arrives.
phew.. I did say it would be long winded! Look forward to the feedback
Lastly.. batteries
