VasiliSk said:accurate for 12F and 6F
tiny bms just started testing, it will be later
Brandon Hartshorn
Asked to be put on the queue for 12fet. Would I be OK with an alien power systems c80100 80kV? Planning on 12s at first, maybe 18s in future
Vasiliy
Im not recomending to use it with RC motors atm
These need some testing and tweaks in code, i dont have time right now to do that
minde28383 said:Who is already running this controller with hub(s)?
Can you compare it's performance with know controllers like sabvoton 72150 72100 7280, max, and kelly 7230, Kelly mini, or other controllers.
cheeko said:What sort of RPM will the 16fet Be like >10000RPM just thinking Mid Drive in Future
brumbrum said:csc said:It's a 2wd setup ! Max battery amps around 175A /17 kw
https://www.youtube.com/watch?v=rvdG_aEzgGE&feature=youtu.be
csc said:Indeed. happier and happier with this setup
VasiliSk said:BMS under development
6F goes to March due to production delay and chinese NY, we are preparing some awesome news
there.redline2097 said:cheeko said:What sort of RPM will the 16fet Be like >10000RPM just thinking Mid Drive in Future
What model are you refering to? There are only 6f, 12f and 24f models....
We put your preorder in the queue. Your preorder № 283C. BMS will be ready for shipping in end of the year, maybe earlier.Dung said:Can u sign me up for 1 x Nucular controller 12F and how long is the queue? When can I expect to receive it?
How about the BMS (the 16s and 24) will it be ready in around 1-2 months, if yes put me on queue too.
People will start to get 12F in April. Your preorder 269C (24F controller)j bjork said:Soo.. Are people starting to get their 12fet controllers?
madin88 said:Any news yet about the size of the BMS and it's connectors?
Will it support single cell voltage monitoring in smaller configurable groups of four or something like that (i mean similar as Adaptto where you can set the number of cells per group from 2-4 and each group is insulated)?
Because in case if someone wants to connect lets say two 10s batteries in series to 20s with a longer wire in between, it would not work well beacuse of the voltage drop or rise between cell 10 and 11 if the connector would be full-length (one uniform part).
Will the BMS support such particular battery configurations?
Your preorder 84C (6F). ETA as we hope, in AprilAeron said:Any news on the ETA ?
Absolute maximum 95V, this will work. Your preorder 284C (24F)Stevebequik said:I have signed up for a 24f when available.
Quick question on max voltage.
Currently running a 22s Chevy volt pack. 92 volts fully charged.
Will this work? Is it likely to cutout on high voltage depending on regen settings?
Turbomatic said:Hello guys! My name is Dima.
