serious_sam
What is the couple mode?PITMIX said:no I use the couple mode
PITMIX said:Hi guys.
With my 24F whether I use the engine brake function or not, when the FW is activated and when I release the accelerator pedal there is a very powerful engine brake. Do you know how I can fix this?
Thank you
Of course, couple=torque. Sorry, I should have recognised that!PITMIX said:Torque sorry :lol:
Very interesting. Did you get this info from Vasiliy or Nuc staff?madin88 said:controller tries to avoid to get damaged from that and so it slows you down until the voltage is safe.
Here it is.serious_sam said:I'll see if I can find the reference
serious_sam said:Very interesting. Did you get this info from Vasiliy or Nuc staff?madin88 said:controller tries to avoid to get damaged from that and so it slows you down until the voltage is safe.
In my understanding, the Nuc limits top speed in FW mode to ensure the back EMF never reaches dangerous levels. I'll see if I can find the reference
Sounds about right.Merlin said:maybe this is the reason why higher voltage setups doesnt gain any speed advantages compared to lower voltage setups ;(
You've got me wondering now. Tomorrow I might do some runs with/without FW, and takes notes of the power requirements and temperatures. I'll report back here what I get.Merlin said:in normal usage to gain 10-15kph more i think your Efficiency loss is below 5%
PITMIX said:@madin88 do you think that using the Qs 138 on a vehicle over 400kg and with a gear ratio greater than 7 engine revolutions for 1 wheel revolution accentuates the problem ?
I think that the inertia created by the weight of the vehicle and the speed of rotation which is at the maximum of what accept the engine in FW, increases the phenomenon. The FW must be adjusted very weakly in this case, so as not to damage the motor.
serious_sam said:But FW is inefficient, so using it all the time just burns power and overheats the motor. It's like a turbo boost button. Only good in short bursts.
Trying to get more speed with a lower voltage pack and using FW is a false economy. You'll need a much bigger pack anyway (more Ah) to pay for the wasted amps used by FW.
Or I can just ride on the same path over and over and look at the screen to see power/speed/temperature. Sure there is more measurement error, but I'm not looking for exact perfect data, but if there is significant difference, it should be obvious.Merlin said:you can try, but "feelings" about how much it makes a different is not really measureable because of so many factors.
I guess the majority of us are using surface mounted magnets, so it didn't cross my mind to consider different effects on different motor types.madin88 said:FW is only inefficient if you use it on motor with surface mounted magnets.
On IPM motors it usually is a good thing since on most of them you can gain RPM and torque so you would even see higher ETA and less heat when using it (over the entire RPM range then)
serious_sam said:2) Seems like ferrofluid (genuine Statorade) doesn't work above a certain speed ? I noticed that after I did the FW runs, the motor would overheat again much more easily than normal, even at lower speeds and after it had cooled somewhat. Possibly the FF creeps away from the air gap due to the centrifugal force, and doesn't immediately return. Not sure. Anyone else had similar experience ?
Merlin said:But how did adaptto and asi sort those things out?
With these controllers you gain massive more speed.
Asi btw is limited to 90v only VS 92v nuc.
There must be something "different" how fw is used![]()
