Trolling the web, but can't find the exact ratios for the N360 Hub.
I know it's stepless, but need the correct min and max ratio to calculate the sprocket and chainring I would need.
Also, what is the biggest sprocket you can fit on the nuvinci itself?
Would use a cyclone 1200W to drive this directly (no crank arms or pedals), so gearing this right is essential.
Might also go for a Alfine 11 speed, as it has a higher range (360% for nuvinci, 409% for the shimano)
However, Nuvinci is stepless, and seems to me better suited for e-bike use (especially high torque, as I don't care about top speed, but ride on trails you couldn't walk on).
