Official start
I lagged on this project a couple times due to financial issues, but finally started buying supplies last night. My setup includes: 150A EZrun ESC, ntm prop drive 50-60 270kv motor, (2x) 6s 20c 5000mah zippy batt.
Few noob questions. Slept for 2 hours because of nonstop research.
1. Since i couldn't find SK motors, what are you guys' view on the NTM prop drive 50-60 270kv motor?
2. I'm using two 6s 5000mah 20c battery to get 6s 10000mah out of it which should give me at least 10 miles. How do I charge and discharge the 2 batterirs at the same time? Is it possible or do I have to use one at a time?
More questions to come. I have a lot of research tabs open, but i need confirmation to avoid damaging my parts.
For the price, you might as well switch over to 63mm. http://www.hobbypartz.com/96m608-bigfoot160-5335-245kv.html for $63.74
And/or you can get it with the extra features for electric skateboards and purchase one with a keyway $90 or do it yourself.
6s 10ah should get you about 10 miles.
You connect to your board in series if you want to double voltage (12S) and/or you connect in parallel for (10ah) but you can't have both.
To charge, you can charge with a Lipo bulk charger. You can charge in parallel to charge multiple packs at once. As for a charger, I'd recommend iCharger 208B and HK 350W Power Supply.
