DanGT86
Not trying to make a big deal out of it. Just trying to gain a better understanding of how controllers work.
DanGT86 said:So am I understanding it correctly that the controller can use switching/logic to actively control the voltage during regen but if you are spinning faster than the no load speed of the motor at a given voltage then it will generate regen power above that voltage regardless of the controller regen being enabled or the throttle position?
Also trying to check my understanding of regen in general.
It seems to me that the controller can manipulate the regen voltage any way it needs to make it higher than the pack voltage. Since it works even at low speeds the controller has to be stepping it up right?
Also if the regen voltage max is set higher than the battery voltage max is it a problem all the time or only when the pack is already full. I have my regen max set to 90v via R12 hack. My pack is full at 83v. Should I be concerned or only when regen braking downhill with a completely full pack? At first I was thinking it would only be a problem if I was going faster than the no load speed of my given motor at 83v. Now I'm not sure.
I'm thinking the pack would pull the regen voltage down just like it does when its discharged and I plug in the charger. Charger is at 83v no load but drops to pack voltage when connected. So if that is the case, having the regen voltage set too high will only be a threat to the pack when its full?
John in CR said:My bikes are too fast now, but back when I had a 30mph bike I don't remember noticing any significant drag when coasting well above no load speed, and I also never noticed any voltage increase like I regularly see with regen braking.
