Aloha,
BACKGROUND:
Built my ebike in 2012 (500w Cyclone mid-drive kit, 24v 20ah LiFePo4 on a standard Montague Paratrooper) with lots of help from Jim Olsen at Cyclone USA and lurking these forums. Rode it as a daily commuter to work in 3 states and haven't really had any issues since building. I moved back home to Maui in 2020 and the bike recently sat in storage for over a year after the Lahaina fires. and I am just now getting back the bandwidth to clean up the bike and get it running again on a new part of the island.
TOPIC OF MY POST:
I am having what appears to be battery or BMS issues. After pulling the bike from storage and connecting the battery to the charger (stock metal ping charger that came with the battery) the charger would immediately cycle on and off, with the 2nd LED light flipping back and forth from red to green - this had never happened before. Eventually, the timing between on/off(red/green) cycles became larger, to the point where the charger finally stayed solid green, at which point I assumed the battery was charged.
I didn't immediately install the battery back on the bike due to ... reasons, and finally did about a month later - no juice/no power light indicator on my archaic half twist shift throttle with red/yellow/green light battery indicator. Removed battery pack from its homemade case and placed back on charger... same on/off cycle, then finally goes green after overnight charging. Immediately test it on the bike, and what I would consider light load/lowest gear, immediately see throttle charge indicator drop from yellow to red - back off the throttle and back to green - not normal for the previous 12 years riding it. ???? Back to the house and back on the charger.
Out of the case and my waterproof wrapping, this is the first time (I'm ashamed to admit) that I have noticed the red light(s) on the BMS. After a bit of online sleuthing, I have learned that these lights indicate a full charge on the individual battery cells as well that the on/off cycling is that BMS attempting to balance all the cells (thanks to Basic Care and Trouble Shooting of a LiFePO4 E-bike Battery). On the BMS while charging, I have 1 solid red light (far left) and no other lights light up - this after leaving it on the charger for about 36 hours.
The charger is showing LED 1 Red and LED 2 Green for long periods with an occasional cycling of "charging." with a Multimeter, I checked the voltage output of my charger at 29.5-30V, where the battery plugs into the motor (red/black wires) at 27.5V. I also disconnected from the charger and unplugged the BMS and checked each cell getting the following voltage readings:
3.348
3.372
3.388
3.385
3.351
3.393
The numbers of each cell appears to be fairly close/balanced, or am I interpreting it wrong? So I'm wondering if my battery is really out of balance? The BMS looks a little....brown/heat damaged in some areas. Should I leave it charging for way longer (up to a week as the referenced Eric Hicks article suggests might be needed)? Might my BMS be damaged and needing replaced? I'm not very experienced with the electrical stuff - I'm a tinkerer/mechanically minded person, but I try to keep things easy as possible. Why is the charger staying green (indicating charge) but only 1 light on the BMS is lighting up. The battery indicator on the bike dropping while under load could just be bike being completely out of tune, needing badly a cleaning/lubing and tune-up. Would it be detrimental to hook it back up to the bike in this state and run it for a while to see what the range is that I get, or better to leave it on the charger for a long time to see if more BMS Lights show up. (sorry for all the what-ifs). I'm not too keen on the idea of buying a new battery, not just for the scarcity of 24V batteries on the market today, but especially with the nigh impossibility of getting a Lithium battery shipped to Hawaii.
Any and all insight would be greatly appreciated.
Mahalo nui,
MojoSlim
BACKGROUND:
TOPIC OF MY POST:
3.348
3.372
3.388
3.385
3.351
3.393
Mahalo nui,
MojoSlim
