I have a scooter sxt 1000w turbo, with engine my1020 48volts, 3000rpm 26.7 ampres.
Specifications attached photos.
Transmission reduction is 4: 1 and I want to reduce to 6: 1.
Tire circumference is 0.87 meters. I think of setting this to 50km / h with the 6: 1 reduction.
Incredibly the result coincided with 24s li-ion. I have have left over 200 cells 18650 of 8.14 w / h and a bms 24s 60 amps .
I imagine it will be very good to climb steep slopes.
Can someone throb over the autonomy that I will achieve under these conditions? weight of the scooter is 50kg my weight 80kg = 130kg total.
problems appear:
lvc of the controllers lead compatible with lithium batteries, high price of the good controller for high voltage, large size and with very exaggerated power.
in this case I think of serially connecting two 36v / 1000w controllers to divide the voltage between it and each operate at 50.4 volts when the li-ion 24s battery is fully charged.
I did not find it convenient to touch the lvc of these controllers. many smd components i do not understand much of electronics and i think that only lvc is not needed, other output voltages, brake, accelerator would also be changed.
I ask my friends who came here to read this long text: Can this work?
my big thanks for all your attention !! Thank you, my name is matheus.
problems appear:
