Toorbough ULL-Zeveigh said:yaaaawn!!!!!!!!!!!!!!!!!!!!Paul_G said:38 lbs!!!!!!!!!!!!
or about the same weight as a typical run-o-da-mill-hub-mobile available now, not vapourware prototype.
jimbo will have to do much better than summ made in indja crappy hubby.
Bike_on said:The bike+system weighed in at 39.8lb.
Toorbough,
You are blowing smoke out your toorba. Being the owner of that "India crappy hubby" from Falco, and a previous Opti owner for 5 years, your under-appreciation for cutting edge technology is nauseating.
Any ebike system running over 500W, 11Ahrs and under 40lbs should turn some heads, not your rear. Instead of dissing new levels of performance, why don't you build your own and compare?
I am squeezing max performance out of the Falco by riding over the 500W spec, much of the time, and using a decent road bike platform, which is pushing the limits of the bike on wheel weight, brakes and vibration. The opti won't have those issues. If I put the Falco on a hybrid and 35+mm tires, with front susp, then it's up to 45lb+ and slower. Plus, Falco- hub vs Opti - mid... what's your point?
Please try to be more creative with your comments.
D
