E-StreetBikes
- Joined
- May 29, 2021
- Messages
- 20
Hey guys i want to know more about parallel battery set ups. When running two batteries parallel what requirements need to be met? Do both batteries need to be identical in voltage, current and capacity? I think depending on the conteoller the current of the batteries can differ. Like if one is 52v 25bms and another is 52v 30bms and their both hooked up parallel to a 22a controller that should be fine right? Also can the capacity if the batteries be different?
