Pawel1976
Hi
I have a 2000W hub motor
2x48V 17.5aH batteries in parrael
Controller 45Amps max
Each battery pack BMS is 30Amps.
1. How many amps should I set the Controller to to be safe?
2. Can you explain to me, do we add BMS together if two batteries are connected in parallel with separate BMS, so the BMS capacity is 60Amps, or its 30Amps?
Should I set my controller under 60Amps or under 30Amps?
Thank you in advance.
Pav.
Pav.
