bnu
I have a yume 52v battery with 2 charging ports
Can I parallel the 2 positive n the 2 neg n charge as one port need help
If it’s a legit Yume battery, then the two ports each accept a 5A charger, so to take advantage of the fast charge rate, you need two 5A chargers (an option for scooters using the pack). I tried to get you to do a couple tests to ensure it’s consistent with the Yume batteries, but you never responded on that stuff.I have a question about the battery what is the purpose of having to charging ports if it's one battery can anybody explain why there's two ports instead of one
This isn’t a support website, it’s a forum. Picture a machine where you add information in, the it gets mixed with a lot of other knowledge, and out the other side pops out a solution. What come out in the end is directly related to what goes in. Better quality input, better quality output. You have to do your part.I'm sorry I'm new n trying to understand the concept of this battery
Let's start over it's an original yume 52v 23AH 14s battery the charger is 58.8 2A that's for 1 port the battery comes with 2 ports I don't understand why u need 2 charging ports for 1 battery
One of my chargers stop working so I came here for some support I decided to charge one side thinking I'll charge the other side after to find out after it was finished charging I couldn't couldn't charge the other side
So I came up with the concept of parallel the 2 post n the 2 neg since it charged
So now u know my situation can it b done if so wat r the down side or it b safe
