RVD
so, i was getting my charger set up to charge 3x4s 5ah turnigy lipos. i usually use a parallel charging board. it's a cheap board that i got from hobbyking last year. i don't use it that often but have been using it for the past few weeks and it seemed to work well. it's a 6x4s parallel charging board.
however, this morning i was setting up my first 3 (of 6) 4s lipos when i ran into an issue.
i plugged in the 3 charging leads first (as usual) and then i plugged in 1 of the balance plugs. i then plugged in the 2nd balance plug when i felt the board get hot and heard a sizzle and smelled some burning. i immediately pulled out the 2nd balance plug and saw that the 1st balance plug had burned out (and detached from the board).
any ideas? just a bad balance board? did i do something stupid again?
i know that i didn't do anything really dumb like have the charging leads plugged in serial and then try to plug in the balance leads in parallel, etc. these were just 3 individual 4s packs plugged into the parallel board.
a few other points of interest that i don't think have anything to do with this but might?
1) the batteries were slightly warm since i had just ridden into work - usually i let them cool off for an hour or so
2) i plugged in the charger first and then started plugging into the parallel board. however, the charger was not started of course. i was going to start the charging after getting everything plugged in.
3) the charger is a cheap 50w imax b6. it's slow but i feel it's fairly safe and it plugs into the ac wall for relatively safe and easy charging at work (where i don't want a fire and where i can't babysit this thing charging). it takes around 6 hours or so to charge and i'm fine with that since i have all day at work.
so any idea what happened here? i'll probably take the 4s pack out of my circulation.
