thunderstorm80
- Joined
- Mar 29, 2016
- Messages
- 383
Hi,
My main battery is A123 79V 20Ah.
On long distances, I add 72V 23Ah Li-Ion battery with GA cells which on the paper is excellent in capacity and supplement the more powerful (but heavier) A123.
On practice, the A123 has a flat discharge curve (~3.3V through most of the SOC) while a standard Li-Ion declines almost linearly from 4.2V to 3V.
The result is that when fully charged, the Li-Ion does it job well while the A123 with it's lower impedance takes most of the load.
But when the Li-Ion fell below 79V, it barely do anything, "waits", and only "kick in" again when the A123 is empty. The problem then, is that the Li-Ion takes the entire load on itself which GA cells don't like on the long term.
I wonder how is it possible to combat this?
I could use DC/DC boost converter, but it will have significant loses and it would be very heavy by weight.
A resistor in series with the A123 will cause even bigger loses, and diodes in series to the A123 will only solve the problem very temporary. (and will have some loses too)
If I were to build a PWM switching circuit in series with the A123, in order just to limit it when desired (without closed loop for voltage monitoring - similar to opening/closing relay but very fast), will it still be heavy by weight, for currents up to 40-50A?
