pchen92
Hi all,
After numerous hub builds and a DH Team + Cromotor that I still run, I wanted to build a lighter ebike with lots of torque.
I picked up a Kona Stinky a few months ago and had fun with it jumping off curbs, wheeling, ... (I live in Paris, so offroad will be quite rare )
I bought a used gng assembly and a #25 chain + sprockets (68T and 11T pinion) to convert the primary reduction.
I don't ride a lot because of my studies but my plan is to get something reliable enough for a few hundreds (thousand) of kilometers before starting changing things.
Controller will be 12 fets controller from em3ev (set at 50A batt 90A phase), cycle analyst (to lower the Amps at the beginning),
Lipo 18s2p (67V 10Ah), additive bag.
So here is the outline:
Keep it 10kg (or more) lighter than the Giant
Reasonable range
Be able to pedal at 30km/h
3 or 4 speed. 35km/h in lower gear, +50km/h in higher. That should get me everywhere.
I hope I can fit a 44t and 48t chainring on the Kona frame
What I need to buy:
-controller
-Smoother spring (I weight 145lbs)
-ISIS Bottom bracket + crank
What I already have/bought:
-tooling
-CA
-higher Seat tube
-Front shimano Zee m640 brake
-Additive bag
-battery
-Eno FW (have to search it)
I will try with the standard cassette first and do some work on the freehub like in this video John Bozi found:
[youtube]PCIe9fgFDTA[/youtube]
If it can't handle the power, I will go with Fourier's solution or screw a few sprocket together, we will see.
Cheers
Reasonable range
What I need to buy:
-controller
-tooling
-CA
-higher Seat tube
-Additive bag
-battery
Cheers
