papertriping
- Joined
- Jul 5, 2014
- Messages
- 71
Hummina Shadeeba said:Ur biggest obstacle I think is since you're doing 1:1 gearing your going to need a super low kv motor. Typically people have a 2:1 or even 3:1 gear for torque. As The motor is now with 250 or even 190kv You'll have a high top speed but not the torque to get there or be able to do any hills. It'll get hot and be inefficient besides being sluggish. A bigger motor will help dissipate the heat but still youll want a lower kv so the motor will be comfortable
I haven't done it yet but still am planning on doing a 1:1 drive so I was researching it a lot myself. Practically all hobby motors are terminated delta meaning the wires in the motor (6 of them) are paired to make your three motor leads. If you identify what individual motor wire strand is going where by finding where they start and end with a led light n battery u can then make a wye bundle and solder half the wires together and then u will now have three half as thick motor leads and one wire thats just the three connected together in a short tail. That will almost halve your kv and its also said to be more efficient and work better with the esc. Reterminating your motor to wye (sometimes called star) will instantly jump you up 10 electronic nerd points
Hey Hummina Shadeeda! Thanks
To be honest I've never worked with electric motors, ESC or Lipos before. Opening up a motor and re terminating seems super complex to me at the moment. I will look it up for sure though! Thanks.
I found this 63-64 190KV motor
http://www.hobbyking.com/hobbyking/store/__39150__Turnigy_Aerodrive_SK3_6364_190kv_Brushless_Outrunner_Motor_US_Warehouse_.html
do u think this will work best for the build?
if i were to run this 190KV motor off 2x3S 5000mah Lipo- what top speed and range(ride time) am I looking at?
would it be 190x6x3.7x0.059x3.1415x60= 46Kph ? (I'm trying to use beto_Pty's equation mentioned earlier in this thread)
