Hi guys
Im new at experimenting with different controllers, batteries etc and I had a question between 20A and 30A controllers.When I swapped my 20A for a 30A I could notice the torque difference right away. Naturally the 30A will eat my battery much faster. However, Im probably wrong, but is most of the extra battery drain with the 30A over the 20A from the start off to mid throttle?? If so, would both the 20A and 30A drain take about the same battery powered wide open throttle since the speed is maxed out with each controller??? Just wondering where I can try and save on battery life if I stick with the 30A controller. The controller and motor are both 48V and motlr is 500W hub bafang motor.
Thanks
Thanks
