ElectricGod
Hummina Shadeeba said:no one talking about free energy from magnets but they can be seen as an eternal potential energy sources. they cant do work alone though. similarly to in a motor when powered they greatly enhance the torque but they need to be oriented correctly to achieve that gain. the extra torque of the motor's pm magnets don't produce any losses in that increased torque production. the magnets do produce other losses but not related to that specific moment of torque produced when they are oriented in a way to do that.
I'm sort of curious where you get this idea?
You get free energy from magnets all the time.
They do work all the time.
Put a magnet on a hunk of steel and hang something on the magnet with a rope. The magnet will stay put long after the rope has rotted away. That's a lot of work and free energy to me. How many times would I need to switch arms when one gets tired? How many meals would I need to eat to keep my arm lifting that object? That's work by any practical definition!
Yes...I know...my definition of work isn't technically correct.
I've messed with pure magnet motors. They use zero electric current and have a stator and armature incorporating magnets. It may surprise you that they can run on their own. The thing to overcome is the magnetic cogging. It is well known that the proper application of iron to a magnet pole can redirect or reduce it significantly. Using this to your advantage, you can create a self running all magnet motor. Magnets can be combined together in specific ways that will create magnetic redirection. This is all well known and documented information. There's not a spinning media hard drive on the planet that does not use these well known principals. Every CDROM drive or motion stabilized camera uses these principals. The more you reduce the magnetic cogging the stronger (more torque) the all magnet motor becomes. My all magnet motors were pretty weak but several did self run. I'm not alone in this. Many people around the world have made all magnet motors that self run and can produce torque. This is NOT perpetual motion. You do have an energy source that creates work.
The reason you never see these motors in use and then are hyped as fake is that anybody that makes one and tries to make it publicly available gets major heat from all the oil and power companies. Those people own the world. The are absolutely 1 billion percent against competition that puts them out of business!!! A motor that runs for 400 years from nothing but magnet power and can generate electricity for the original cost of the magnet motor and generator...well that would certainly put a giant dent in their strangle hold on the world!
Back to magnet cogging...
Unfortunately, you need the interaction of an induced magnetic field on a stator tooth with a magnet pole to make a motor work. Can you eliminate cogging in a BLDC or PMAC motor? I think probably no.
